any tech wizards around here...using a monitor as a TV
  • lolcantturn
    • 4588
    Basically I'm moving into my dorm tomorrow and I want to setup my monitor as a TV since I don't use it. It's a pretty decent 30" LCD display and it would work great in my dorm. I have cable coaxial TV in my dorm, but the problem is the monitor is a VGA connector and I'd have no idea how I would convert the video and audio signal the Coaxial provides and divide it to display the video signal of the VGA, and split the audio into speakers.
    Basically, I'm wondering how I can use a coaxial TV connection to be compatiable with my VGA connector of my monitor. Thanks.
    Originally posted by TSI
    OEM+
  • Asbradley21
    • Jun 2008
    • 1938
    Yep it can be done with one of these.
    S54B32 swap in progress. Status: Getting There
    • pureaudio
      • 1123
      You need a tv tuner for you computer. The coaxial will hook to your computer and use the video out from your computer to your tv.
      Edit: I misread, is there no computer in the equation?
      • Raxe
        • 5346
        AFAIK you still need a computer to 'translate' the analog coax signal into a digital format a VGA monitor can understand and display. A monitor doesn't have that processing ability, but there may be dedicated boxes that do that now with the popularity of HDTV on the rise.
        • lolcantturn
          • 4588
          Awesome! Will I need my computer? I'd like to do it without a computer
          No computer involved
          much appreciated!
          OEM+
          • AndrewBird
            The Mad Scientist
            • 11897
            Do you use a cable box already, or is the coax coming straight out of the wall? If you are using a cable box, it should have RCA outputs already that you can then just get an adapter from RCA video to VGA. If it is just coming out of the wall, you need some kind of tuner box.
            • lolcantturn
              • 4588
              It comes out straight from the wall
              OEM+
              • Asbradley21
                • Jun 2008
                • 1938
                much appreciated!
                Nope. It runs as an independent set top box, just plug in your coax, VGA, speakers and power and you're good to go.
                • iidesu
                  • Jul 2011
                  • 124
                  um...I'm wondering the same these days...
                  gabriella psychic
                  • Massimo
                    • Jan 2008
                    • 3207
                    Please correct me if I am wrong but don't some recivers do this aswell these days. Other wise pick up a $20 TV tuner card and put in you PC.
