1999 540i valve noise
  • snitzer
    • Jul 2008
    • 137
    I'm helping a buddy with his 540i... it's been parked for a while with a bad water pump. We replaced it.. all went well... it had a little valve train noise which i attributed to it sitting for about a year. it now has a lot... no warning lights, etc are present car starts and runs fine. Fluid levels are good.
    I've searched online and am coming up with a lot "Vanos unit" stuff. As I understand it , this is usually not an issue with the 540i's.
    Has anyone run into this?
    Thanks
    here's a short video.
  • Car Addict
    • Mar 2007
    • 1100
    drop the pan if you see plastic bits (which i can almost guarantee you will) you need to replace the timing chain guide rails, approx. a 10-12 hour job if you know what you are doing.
    • snitzer
      • Jul 2008
      • 137
      thanks... i'll jump down that rabbit hole.... and i don't know what i'm doing so it will take a 3 day weekend and a keg of beer ...
      • Car Addict
        • Mar 2007
        • 1100
        ^ pretty much; if you do go that route be sure to do the oil separator while you are in there.
