Engine stand thread.
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    what kind of engine stands do you guys have, and what weight capacity?
    i think i may have to get one soon and i'm looking for the best bang for my buck!
  • pureaudio
    • 1123
    Harbor Freight? Only one I have ever used and it held up an engine as well as it claimed to.
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      thats pretty much what i'm thinking so far....
      i just have to figure out how im gonna get the engine out.
      how heavy is an m20b27???
      • LJ851
        • 7918
        Do NOT get one with 3 wheels. (T shaped).
        Lorin
        The M30 is God's engine.
        • rares
          • 730
          why not the t shape?
          • Pantless Spency
            It's McRib time!!!
            • Feb 2011
            • 7283
            the one im looking at (1 ton stand from harbor freight)
            is an I shape but the two front wheels are only about 8 inches apart it looks like.
            • LJ851
              • 7918
              Way too easy to tip over, especially with an inline 6 engine on it.
              Lorin
              • deutschman
                • May 2008
                • 5958
                I have the T shaped stand, and I will tell you my m20 started to tip and I had the ketch it. I am a big guy and my brother ran out and helped me so no harm was done, but unless you can weld on an extra cross bar up front do not get it. Spending large amounts of time and money on an engine and then seeing it fall over and eat shit is hart braking.
                How ever if you can weld or just want to bolt an extra piece of 2x2 square tube up front with some extra casters, the T shaped stand is cheap as it will get and does hold an m20 very well.
                • dannyyisntt
                  • 3141
                  I have the T shaped one nobody recommends. On the bright side, my m30 hasn't had an issue with the stand.
                  • LJ851
                    • 7918
                    I bought this one, it has served me well.
                    http://www.oreillyauto.com/site/c/de...5.oap?pt=N0767
                    Lorin
                    • MaksV
                      • 1042
                      get the 4 wheel 1000lb one from HF. Very stable and easy to use.
                      CHEAP REBUILT INJECTORS
                      Need Quality Brakes? BimmerBrakes has it!
                      For anything Else go with BluntTech!
                      • bmwmech1
                        • Jun 2010
                        • 1075
                        In a recent issue of Hot Rod, they compared and tested the "cheapy" stands and the 1 ton I shaped one from HF withstood something like 2300lbs of force before the plate that the motor bolts to deformed. Nothing else broke or deformed, which is pretty impressive for an inexpensive stand. I have the I shaped stand and used 4 of the T shaped stands to build my rotisserie, so I can say they work as good as anything else out there at 3 times the money. Catch the T shaped one on sale and that is the best bang for your buck... and spend the money you saved on the motor!!!
                        Garey
                        • Chaz
                          • Jul 2011
                          • 432
                          Possible/worth it to weld an entire stand yourself?
                          • Mlarsen
                            • 4082
                            I got the same one, its awesome.
                            • TimKninja
                              • 2131
                              Had the Derpalast one from Autozone. Held both M20s and an M50 no problemo.
                              1985 325e M50TU(Sold)
                              1991 318is Slicktop (Sold)
                              1990 325is Brilliantrot S50/5 Lug Swapped.
                              1992 525i Manual shitbox Winter Beater
