HELP! ps3 and resolution, hdmi
  • devon.818
    • Feb 2011
    • 2937
    hey guys, bought a ps3 from a guy at work. it came with an HDMI cable, but only the HDMI cable. i hooked it up to the TV, and nothing.
    i know it has to do with the resolution, already reset the thing back to the lowest setting by holding the power button, but that didn't work.
    what am i missing? i get no picture.
    any help would be awesome
  • GThomas
    • Dec 2010
    • 869
    If the previous setting was to set the output to something other than HDMI it may be reverting to that setting.
    1991 318is S52
    1987 325i Vert
    1991 325i
    2011 e70 X5
    Need Anything E30? -> http://www.gutenparts.com/
    • lambo
      Captain Scene Points
      • 10953
      Buy a 360?
      If it's transmitting in the lowest resolution, I don't think it will transmit through the HDMI port.
      • Fleksta
        • 182
        With the system off, press and hold the power button for 5 seconds or until you hear a second beep.
        1987 325e - 5 speed - Mods: 3.25 LSD, Mark D Chip, Bilstein HD's, Ansa Sport
        • devon.818
          • Feb 2011
          • 2937
          did this multiple times
          • GThomas
            • Dec 2010
            • 869
            Bad HDMI cable possibly.
            1991 318is S52
            1987 325i Vert
            1991 325i
            2011 e70 X5
            • devon.818
              • Feb 2011
              • 2937
              if i reset it to lowest setting will the hdmi cable work, or do i need to pick up a set of regulr 3way aux cables?
              • GThomas
                • Dec 2010
                • 869
                Try another HDMI cable, if not the av out (3aux) needs the special PS3 adapter for the back and they are around 30 bucks. Try a different TV also, that way you can trouble shoot your signal flow before buying things you don't need.
                1991 318is S52
                1987 325i Vert
                1991 325i
                2011 e70 X5
                • lambo
                  • 10953
                  That's what I was trying to say. I don't think it can output 480p (or whatever the lowest setting is) through HDMI.
                  • devon.818
                    • Feb 2011
                    • 2937
                    so is there a way to bump it back to HDMI to the RIGHT setting?
                    see, me and lambo here are on the same page with this shit.
                    • Flash
                      • 688
                      i had to do this with mine, i had to hook it up with the composite cables and reset the stuff through the settings or held the power button for like TEN seconds. You can download the instruction manual PDF online if that helps.
                      • lambo
                        • 10953
                        I think you need to get some A/V cables. Go to Gamestop and try to find some used ones and return them when you're done.
                        • straight6pwr
                          • Sep 2004
                          • 3450
                          holding down the power button doesnt set it to the lowest resolution. after you start it that way, it searches through the outputs until you can see it pop up on the tv. make sure the tv is set to the correct input and try again, but let it work for a few minutes (each setting may take 30 sec, and there are at least 5 different settings)
                          if this doesnt work, start troubleshooting.
                          1)check another hdmi devise with said tv
                          3)try new hdmi cable
                          4)try a standard def ps3 connection (the one that comes in the box)
                          • devon.818
                            • Feb 2011
                            • 2937
                            ahh so keep doing the button trick till it comes on screen.
                            • Nick_S
                              • Apr 2011
                              • 3658
                              Have you tried yelling at it or hitting it with a blunt object?
                              91 318is M50 swapped
                              05 Honda Pilot
                              24V swap thread
