loctite removal
  • EuroTrash///E30
    • 128
    loctite removal
    The PO of my car put a custom shift knob in my car, and put loctite on it so it wouldn't come off. I want to take it off so I can refinish it (it's wood, so I want to sand and stain it.) So is there anyway to remove it without breaking anything?
  • LJ851
    • 7918
    Heat will break it down but prob not before wood knob suffers damage. Do you know which loctite was used?
    Lorin
    The M30 is God's engine.
    • EuroTrash///E30
      • 128
      No, I don't know what kind he used.
      • slammin.e28
        שמע ישראל
        • 12054
        Remove whole shifter and refinish the knob while attached?
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          Which loctite was used?
          • EuroTrash///E30
            • 128
            I don't know what kind he used. I'm sure it would help if I did. Sorry
            • Thizzelle
              • 4422
              can you see the color of it?
              red you need heat
              black need heat
              blue can just crank it
              "I wanna see da boat movie"
              "I got a tree on my house"
              • EuroTrash///E30
                • 128
                Nope, can't see the color. I'm sorry for my lack of information.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  • m73m95
                    • May 2011
                    • 319
                    Don't heat the knob...heat the lever! Wood can withstand quite a bit if heat (The finish can't, but you're refinishing it anyway).
                    Just heat the lever with a propane torch until its too hot to touch, but not hot enough to change color.... then twist the knob off.
                    • Fusion
                      • Nov 2009
                      • 3658
                      On a similar note: Is there something wrong with blue loctite if it doesn't want to dry up and seems to stay liquid?
                      • BillBrasky
                        • Dec 2008
                        • 1641
                        Anaerobic sealants only cure where no oxygen is present. The surface that you can see on the outside usually stays in a liquid state.
