indy car vs F1
  • grahamsy2k
    • 400
    indy car vs F1
    Hurry Im in a fight with my friend and she is sayin indycars go faster and longer and is overall better then F1.
    she said "F1 could never go 500 miles" ha
    I need some come backs
    All just means to an end.
  • camip
    • Nov 2011
    • 1253
    F1 can turn both right and left.
    • pandaboo911
      • 2070
      she's probably right, F1 transmissions don't last very long. but indy cars certainly aren't faster
      • Rustyduktape
        • Jul 2008
        • 592
        indy cars now have fenders, or something like them, haha.
        1987 325is Black/Black
        -91k
        -Stock (mostly)
        • grahamsy2k
          • 400
          well indy car does do some road courses. Now if we were talking nascar then yes.
          • grahamsy2k
            • 400
            I need statistics
            • slammin.e28
              שמע ישראל
              • 12054
              ....bitches.
              • lolcantturn
                • 4588
                Pics of your friend or get the fuck out.
                Originally posted by TSI
                OEM+
                • grahamsy2k
                  • 400
                  I only have naked ones so..
                  • grahamsy2k
                    • 400
                    but only after statistics
                    • pandaboo911
                      • 2070
                      indy cars are built more for top speed(oval track). 240mph
                      F1 is built for maximum downforce for cornering, 220mph top speed
                      indy cars are much heavier but also much safer
                      nao pics
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        That's what PM is for. ;)
                        lolwantnudescantturn
                        • lolcantturn
                          • 4588
                          Specifications (2007-2011)
                          [edit] Chassis
                          Firestone Firehawk tires Type: Open-wheel, single-seat, open-cockpit and ground-effect underbody; outboard wings front and rear.
                          Construction: Monocoque contains cockpit, fuel cell and front suspension; engine is stressed (integral) member of chassis; rear assembly contains bellhousing, gearbox and rear suspension members.
                          Materials: Carbon fiber, kevlar and other composites.
                          Weight: 691.7 kg (1,525 lb) minimum for ovals and 725.7 kg (1,600 lb) minimum for road courses, including lubricants and coolants. Does not include fuel or driver.
                          Length: 192 inches minimum.(487.68 cm)
                          Width: 78.5 inches maximum(199.39 cm), 77.5 inches minimum(196.85 cm) (measured outside rim to rim).
                          Height: Approximately 38 inches.(96.52 cm)
                          Wheelbase: 121.5 inches(308.61 cm) to 122 inches(309.88 cm).
                          Wheel Size: Front: 15 inches(38.1 cm) diameter, 10 inches(25.4 cm) wide Rear: 15 inches (38.1 cm)diameter, 14 inches(35.56 cm) wide.
                          Tires: Firestone Firehawk Front diameter: 26 inches maximum, 25 inches minimum @ 35 psi Rear diameter: 27.5 inches maximum, 26.5 inches minimum @ 35 psi.
                          Gearbox: XTRAC (gears forward of rear axle) Six forward gears (Manual), Mega-Line Assisted Gear Shift (paddle-shift).
                          Fuel Cell: Single, rupture-proof cell, 22 U.S. gallons (standard).
                          Manufacturer: Dallara Automobili.
                          [edit] Engine
                          A 2008-spec Honda Indy V8 Type: 3.5-liter (213.6 cubic inches) V-8, 32-valve dual-overhead cam (DOHC), Normally aspirated (no turbocharger) Max. bore diameter 93 millimeters Four camshafts, four valves per cylinder.
                          Weight: Minimum dry weight is 280 pounds - no headers, clutch, ECU, spark box or filters.
                          RPM: 10,300 (rpm) maximum (league-supplied rev limiter).
                          Power output: 650 hp (485 kW).
                          Fuel: 100% fuel grade Ethanol.[15]
                          Injector: Electronic.
                          Models: Honda Racing Indy V-8.
                          Manufacturer: American Honda Motor Co., Inc.
                          Red Bull RB8 F1 car
                          specifications
                          Engine:
                          Renault engine RS27 - 2012
                          Cylinders:
                          8
                          Capacity:
                          2400CC
                          Max rpm:
                          18,000rpm
                          Number of Valves:
                          32
                          Vee Angle:
                          90 degrees
                          Power Output:
                          Not Disclosed
                          Engine construction:
                          Cylinder block in cast aluminium
                          Engine management:
                          FIA (MESL) standard control unit TAG310B
                          Oil:
                          Total Group
                          Weight:
                          FIA minimum weight of 95kg
                          • Chassis
                          Composite monocoque structure, designed and built in-house, carrying the Renault V8 engine as fully stressed member
                          Transmission
                          Seven-speed gearbox, longitudinally Mounted with hydraulic system for power shift and clutch operation. AP Racing clutch
                          Suspension
                          Front: Aluminium alloy uprights, carbon-composite double wishbone with springs and anti-roll bar, Multimatic dampers
                          Rear: Aluminium alloy uprights, carbon-composite double wishbone with springs and anti-roll bar, Multimatic dampers
                          Brakes
                          Brembo calipers, Brembo carbon discs and pads
                          Electronics
                          Fuel
                          Total Group
                          Wheels:
                          OZ Racing
                          Front:
                          12in x 13in
                          Rear:
                          13.7in x 13in
                          Tyres:
                          Pirelli
                          Brakes:
                          Brembo
                          OEM+
                          • lolcantturn
                            • 4588
                            you make me want to stop posting for da rest of mah life
                            OEM+
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              Peas don't! I enjoy lol....cantturning. Makes mah day! YOU MAKE MAH DAY!
