Pressure Washer Wont Start?
  • BlackbirdM3
    • 2770
    Check the oil level in both the motor and the pump. I'll bet one of them is low. That is why it won't start. We have 2 pressure washers at work and when ever they won't start, I check the oil, add the required amount and then they work fine.
    Will
    '88 BMW M3
    • u3b3rg33k
      • Jan 2010
      • 2452
      Originally posted by 5Toes
      Okay I have torn into this thing and done all this:
      Last night:
      - polished magneto with 1000grit sandpaper then degreased
      - Re installed carb to find that the linkage is jacked. The choke works great, but the throttle/governor linkage is messed up... the thing is always at full throttle. Cant figure out how it works though, and spring seems springy enough. The repair blow apart diagrams didnt help much at all.
      So I guess I found the problem? lol
      Governors usually sit at full throttle when the engine is at 0 RPM - at least on small engines they just limit engine speed.
      I bet that magneto is real purdy right now - but probably works just as well as before...
      Ich gehöre nicht zur Baader-Meinhof Gruppe
      Originally posted by Top Gear
      Just imagine waking up and remembering you're Mexican.
      Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
      • 5Toes
        • 9836
        Well, the way the throttle linkage is right now, it doesnt adjust anything
        I added a little oil, it was right below the lowest mark. Pump oil is fairly fresh
        • GDA
          • 446
          Based on what you posted so far... suggest the following:
          Pull the plug
          Put in fresh gas
          Pull the starter on it at least a dozen times to run any old gas through the lines and all
          Blow compressed air into cylinder to dry it out
          Reinstall clean dry plug and then try to start it
          • 5Toes
            • 9836
            Okay
            • Axxe
              • Aug 2004
              • 3355
              Have you tried the starter fluid trick? Or a sniff of gas down the carb?
              Keep it slideways!!
              • 5Toes
                • 9836
                LOL... put it all back together.. fired up first start!
                Today I:
                - cleaned the air filter housing
                - re installed gas tank
                - Took throttle/governor spring and cut 2 or 3 coils out out of it (to make it stiffer)
                - Added fresh gas
                Now it idles too high though. Pulled back all the covers and saw that the spring was too tight. Loosened up the spring and put it back on.
                Idling without the trigger being pulled is still too high
                With trigger pulled (load) it is perfect. Any ideas?
                I am thinking my spring is just not right and I messed it up... off to order a new one
                • Cephas
                  • Apr 2012
                  • 878
                  Troubles with starting small engines are carb related 95% of the time. Glad to hear that you got it fixed.
                  • Todd Black 88
                    • Oct 2007
                    • 3449
                    Yeah, you screwed up the spring. They are very flimsy things.
                    Originally posted by codyep3
                    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                    2001 silver/Blk 325 cabby. SOLD
                    2002 325xit Sil/blk. SOLD
                    2010 F650gs twin
                    • 5Toes
                      • 9836
                      I have since learned. Ne wone on the way... $3.49
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        By cutting the spring to make it "stiffer" you shortened it, changing the default setpoint. just an FYI.
                        • JinormusJ
                          • 6887
                          Shoulda done dat 60k mile tune-up waffleswaffleswaffles
                          • 5Toes
                            • 9836
                            I cut it and stretched it a little. No big deal, it works good enough for right now.
                            New spring should be here by next tuesday
