I have an ice maker I want to fix. I plugged it in, turned the switch on but nothing happens. I can only hear thag "power sound". So I started measuring various connections and I can't get a good readout. The ground wire seems fine, although the bottom plate has some rust and residue. Nothing happens when I disconnect or connect the ground somewhere else.
What can I try to rule out a bad ground?
The controller board looks fine, capacitors are ok. No burned or damaged parts.
No power light btw. and there are two transformers 220V->24V for most things and 220V->100V for the gear motor, the compressor is 220V iirc.
