ignition cylinder removal
  • bmwstephen
    • 2463
    is it possible to do so without having to remove the steering column pieces? i heard you just have to insert a pin into a little slot that appears after turning the key position 1?
    friend's key is stuck
  • Fourbanger
    • Jul 2011
    • 335
    The hole is accessible on late models (where the metal meets the round black trim piece) but IIRC you have to remove the steering column pieces on early models.
    It doesn't actually appear, the tumbler just needs to be turned before the hole lines up with the internal release mechanism.
