Help me wire this?
  • illest318i
    • 1472
    Help me wire this?
    Hey guys! I bought a keyless entry on amazon and received it today. I was looking at the wiring diagram and I don't understand it. I have no clue how to wire this thing, but maybe some of you guys do.
    The pictures below are of the diagram itself:
    Sorry if the pics aren't any good. I can post more of you guys are having trouble seeing them.
    Thanks in advance guys.
    IG: @_j.wn
  • AndrewBird
    The Mad Scientist
    • 11898
    Look up your car here for the factory wiring:
    http://www.the12volt.com/installbay/...yeard/BMW.html
    You can also find the factory wiring diagrams here:
    E30's are negative trigger, so you want to use Diagram C in your instructions. So it should look like this:
    Keyless------>Car
    White----->Yellow/Blue
    Yellow----->Ground
    White/Blue----->Green/Blue
    Yellow/Blue----->Ground
    Then the red and black wires to power and ground.
    The red/black wire is for a electronic trunk pop, but E30's don't have one, so you can either leave it unhooked or hook it to another accessory you want to turn on.
    The brown "direction light" is for the parking lights. If you want the lights to flash when you lock/unlock the car, hook this wire to the parking lights. Otherwise, leave it unhooked.
    • illest318i
      • 1472
      Ok cool, but just to make sure I get this right, I hook up
      White with yellow/blue and so on as the list goes?
      Please correct me if I'm wrong. And thank you for your help.
      IG: @_j.wn
      • AndrewBird
        The Mad Scientist
        • 11898
        Correct. You will need to splice those wires into the car's harness.
        • illest318i
          • 1472
          Awesome!
          Thank you very very much.
          I'll report back if anything goes wrong.
          IG: @_j.wn
          • illest318i
            • 1472
            Okay so I'm taking a look at this and wonder "how am I gonna hook this up?"
            I take a look and there's more wires than I completely thought!
            I was looking for that yellow/blue wire and I couldn't find it.
            Do you mind pointing out, wire direction? :)
            Here are some pics of this mess.
            Thanks once again
            IG: @_j.wn
            • quikveedb2
              • Sep 2007
              • 2258
              Iirc most people hook it up in the trunk.
              Here's a link to the DIY;
              You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
              • AndrewBird
                The Mad Scientist
                • 11898
                The wires are inside the kick panel. Take the kick panel off and take the speaker out and see inside.
                You can also do it in the trunk however.
