E53 X5 4.4l: M62 or N62?
  • fronton
    • Oct 2009
    • 1262
    I need a tow vehicle for ~4,000lb boat/trailer and am trying to decide between the M62 or N62 E53. I am open to a newer X5 but prefer the look of E53 as well as less electronics and crap to go wrong. Researching the pros and cons this is what I believe is generally agreed:
    M62: more reliable but less power and obviously stuck with 00-03 models. Get the 2003 if going M62
    N62: more power but less reliable mainly due to more complex management and worse coolant system design. Tranny is worse than M62's. Main expenses (if lucky) are intermediate levels and Get the 2006 if going N62
    Is this accurate? I would rather sacrifice power and MPG for reliability but I'm sure there is more to it. What preventative maintenance should I make sure has been recently done or need to do myself if buying either one?
  • Dozyproductions
    • Jan 2007
    • 4682
    Which ever one you want that'll fit in an e30 after you wreck the e53... on purpose.
    • Danny
      • 14216
      M62 you'll eventually do a timing chain on. N62 you'll do a coolant pipe and valve stem seals on.
      I would go with an M62.
      • dirty30
        • 3112
        Run away from either.
        • redsubdivisions
          • Feb 2011
          • 1762
          M62.
          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
          2012 Passat TDI - DD Duty
          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
          • Axxe
            • Aug 2004
            • 3355
            4th Gen 4Runner with the 4.7. 7000lb towing capacity, 18mpg, Toyota reliability (aka, don't have be nervous about all the little crap you would be with the X5).
            Keep it slideways!!
            • QUKBMER
              • 8178
              This ^^^^
              • dirty30
                • 3112
                This or a Landcruiser 100 series
                • fronton
                  • Oct 2009
                  • 1262
                  So which is the best year of the 4th Gen v8 4runner?
                  • myinfernalbmw
                    • May 2007
                    • 1736
                    '08-'09. Limited, if you can swing it. It'll be my next truck unless I go with a Tacoma.
                    • fronton
                      • Oct 2009
                      • 1262
                      Thank you, it looks like fourth gen is the only one to offer v8! Seems lame that the v8 only has ~10% more power and torque than the v6 though. I suppose that is just enough to make towing a 4,000 load up windy mountains a lot better than the V6. I wonder if it's worth the worse fuel economy for 99% of the driving though.
                      • volvolover
                        • Jan 2014
                        • 89
                        Anything made in 'murica!
                        cheaper on parts and insurance!
                        • freeride53
                          • 11972
                          Toyota 4Runner has my vote for sure. I want one badly.
                          1983 Peugeot 505 STI
                          1992 Volvo 240 Wagon
                          • totheredline
                            • Jun 2013
                            • 762
                            +1 on the yota
                            Sent from my XT907 using Tapatalk
                            = Heidi 1988 325 -> 335i. 7200rpm built M30
                            • Bimmerman325i
                              • 6854
                              Suburban
                              2017 Chevrolet SS, 6MT
                              95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                              98 M3/4/5 (stock)
