Why Stomp Test No Work???
  • eceninit1976
    • Dec 2014
    • 1
    I have a '92 e30. The stomp test has never worked for me. Checked the DME - it is a 0 261 200 525 - the latest one installed in the e30s. That is a Montronic 1.3 DME - should support the stomp test. So what gives? Why does the stomp test not work?!?
  • cgk_iii
    • Dec 2012
    • 616
    If ur throttle cable is worn you might not be getting wide open throttle. Have someone turn the key to and open/close the throttle by hand to see if that works
    • Adrian_Visser
      • Jun 2006
      • 2823
      More likely the throttle position switch is fucked. You can test it at the pins on the connector with a multi-meter. Just push the throttle by hand.
      '89 Alpine S52 with goodies
      • Stanley Rockafella
        • Aug 2011
        • 4062
        yeah, either the TPS is screwed, or you need a different chip/ECU combination (that's the only way I could get it to work on my e30. I have the 173 ECU
