SHITTTY Day karting yesterday!! =(( [V Long...]
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    Ok, this is really really long, so here's cliffnotes. Broke chassis in race 1. Borrowed friends "extra" chassis in race 2 and 3 with my motor, lost drive on first lap of race 2. Another friend hit me and wrecked hard into tires but is OK, but red flag came out. Bent my spindle, replaced it for the re-run of race 2. Won. Race 3 started pole again, and my motor started cutting out so I ended up 3rd, but 2nd overall between race 2 and 3 (heats 1 and 2).
    Location - ThunderHill.
    So, my first race of the day was a half hour long race. About mid way through it I got airborn coming back down from turn 5 when some idiot did a stupid move ahead of me. He parks it in just about every corner, and decided to try to pass someone coming down the hill, as I was already trying to pass him. Say it was halfway my fault, but jesus, he was going almost just jogging pace and knew I was right behind him. He had seen me go through that corner several times, and knew I was faster. C'mon man, dont be stupid. It's a wonderful passing spot, and I was about to take him back but I just couldnt get around him enough and ran over his LR tire. This sent me way off the track in the weeds, doing some agricultural racing. I made it back on the track, just wooding it all the way back, probably at least a good 50 feet away at the apex of my arch.
    From there on, my kart didnt feel that great, it would pull to the right if I let off the wheel, and was much more nervous through the corners. I hoped it was just a bent spindle, tierod, rod end, something simple, but I couldn't see anything wrong while I was out there so I just kept racing. I was in 1st, and now I was in 3rd but I eventually did catch back up with the guy that I jumped. Damn, he really did take corners really slow, but he had a rotax (Different engine that typically has more top end on road courses) and would stay with me from my draft and pass on the straights. I ended up actually finishing behind him because of that, so 3rd place. Bullshit though, he couldnt drive for shit. He told me he was sorry about that turn that I got into him at, and also that he was freaked out a little when I was ahead of him piling into corners, sliding sometimes at 45 degrees. I find that slightly unlikely, maybe about 20, but only for short periods of time correcting through it so I can get through faster on the gas. Cmon. Oh well.
    Well Rick comes up to me, a buddy of mine that seems to have plenty of money on his hands to play with and asks me if that was me off in the weeds. I say yah, and that my chassis is probably tweaked now. He lets me know that he'll let me run his kart that has a Sonik motor on it that he stuck (for the 3rd time in 2 race weekends) if I need it. I told him I probably dont, but I'll let him know. As I got back to my pits I got my kart up on the stand and looked at the RF corner. Chassis was cracked most of the way around, WTF? I jumped one person, and took a little off track excusion, and it broke the damn thing, its not even that old either?! End of that story is going to tell Rick I need the kart and we both have a thrash session minus him eating lunch for me to get his motor off, and mine on his kart. Besids some small differences, there was one I didnt think would be a big deal so I put his chassis clamp "butterflies" back on to hold my motor and motor mount down. The chassis rail spacing was just slightly different (wider) so I used his, but they were not the flush style that are even with the bottom of the frame rails, instead they stuck at least a quarter inch down. No big deal I thought, at the time....
    My second race came around after lunch and I took to the track with Ricks kart, my engine, his belt drive, and his chassis clamps. THe kart was certainly not set up for me and I'm really really sore today but thats not the point. On the first flying lap, I got a little wide in one corner coming back onto the back stretch. On the outside there is shallow rupple strips and most devistating, a bunch of lines of those stupid traffic turtles just past where the strip ends. Problem with those is I hit one, it tore out one of those non-flush mount clamps, and with enough force to do that, it obviously slid the whole thing back enough that the belt disengaged and I had no drive power. Pure coasting from there, so I put my arm up high and started to SLOWLY make my way off to the edge of the track on the outside where there is sort of a small paved road area where I could have pulled off instead of into the dirt. THere was a problem with that though when I was most of the way there, when Scott, another good buddy of mine that is(was) in the points race and I would have had to finish every race ahead of him to get 1st, tried to pass on the outside and clipped my rear tire and shot in into the tire barrier at almost full speed. He's okay, minus a seriously swollen ankle from trauma, but his kart certainly is not. Bent his rear axle on impact with my(Ricks) kart at about a 45 degree angle, folded his nose under the kart, flattened the driver fairing, bent both spindles, made at least one of the tierods into a U shape, and the frame itself couldnt be in that great of shape either. The race was red flagged and was rescheduled after the next race that was to happen after us.
    The only thing wrong with Ricks kart was a bent spindle, so I replaced that just in time and was ready to try round #2. The first heat was reduced to 5 laps, and I won with a rather large margin. Placing first there, put me on pole again for the 15 minute (instead of 20, times were reduced) 2nd heat. I wasnt quite so lucky in that one, but just enough to finish. About half way through the race my motor started cutting out whether I was full throttle or not, it would just lose all power. It got progressively worse throughout the race, and 2 of the guys in my class caught up to me. I ran with them for some time but the power just wasnt up to it. On the last lap it got REALLY bad coming down the front straight and I almost thought I wouldnt make it to the start/finish but it kicked back in just enough to pass by and place 3rd place. How the rest of my class didnt catch me, I have no idea.
    Of course though, if the race was any longer I would have DNF'ed when the thing completely died in turn 2. Fuel wasn't all the way up to the carburetor, and if I choked the airbox it would fire up and idle but wouldnt rev enough to move me around the track.
    It was a shitty weekend for me, but it helped me in the points I guess.....1st and 3rd was better than the 3rd and 2nd of someone I had to beat overall in the points in 2 out of 3 of the remaining races. One of those 2 is down. I'll have to check the points system to make sure thats still the case though if I finish 2nd over 3rd not 1st over 2nd. The points gaps may be different. Scott on the other hand I would have had to finish every race ahead of him, but I think he's out of the running because he didnt get any points at all for this race as he didnt even officially (re) start it. :weak:
  • nkell09
    • Jan 2004
    • 575
    Any pics of the action?
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      Unfortunately no. Well, I take that back. My mom was there and she was taking pics of some stuff, I have no idea what all they were of though. Lemme go check. I dont think there are any pictures of Scotts kart, but it's fubared.
      • Justin B
        Sikky Nar Nar
        • Mar 2005
        • 4273
        Some time during the first race, in my own kart-
        Chasing down the guy that I jumped. I cant tell if its before or after I went off -
        Most certainly after I went off, about to put it on my stand and discover the crack. Nice radiator huh?-
        Here it is-
        Dad doing something, my enigne and everything on Rick's kart-
        The wreck, sharpened up a bunch because you really cant see anything at all. Scott is lying down and myself and some other guy are there-
        Pace lap for the restart of Heat 1, I am on pole, outside of this picture-
        Rick is in front, and I am behind him there, chasing him down with his own chassis :) -
        My class originally had 8 people in it, but Scott did not restart, and someone else apparently didnt restart either I just noticed now. Anyway, i dont only race with a couple other people like it appears up there in the pace lap, there are several other classes that start ahead and I can make my way through.
        • cahomey
          • Mar 2004
          • 1201
          Where are the green and red turtle shells and banana peels?
          "It's like a koala bear crapped a rainbow in my brain."
          R.I.P. Harry Goz aka. Captain Murphy
          "My ride, My ride, she don't beg, steal, cheat, or lie,
          My ride, My ride, and our relationship is classified."
          • golde30
            • 11464
            LMFAO.
            JBizzle, looks like an eventful weekend of karting...hehe. ready to take a break and finish up my m42;-) ;-) ;-) ? hahaha. whats the damage $$$ for yer cart? new frame, or re-weld?
            IG: @Baye30
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              Im going to try to find out tomorrow when I bring it into work and have it aligned with some laser dealio. If the chassis has a tweak in it static, without weight in it (sitting on a kart stand, no weight on the wheels), there is a 99% chance it's toast, unless its within enough of a spec that I can dial in the adjustment to zero it out in the (rather limited) front end adjustment. A new chassis is ~$1200 last year. I broke my first one and got this one for free, 6 months later =/...I need a new chassis in two weeks. If i have to shell out to get one and nobody will pay for it for me, that's one thing, but the new ones also use a newer style braking system. I kinda like my brakes, theyre not optimal, they work wonderfully for my feel but are a complete bitch and a half to bleed. My biggest gripe with getting a new frame is if i have to buy a new brake system too, that'll certainly suck, and add a lot to the price tag. Yeah, I should be available Saturday, I'm not working. The only thing I see that could get in the way is some frame disassembly, or some other kart related "fun" activity =/. Unlikely I'll be able to do that though considering the guys I bought the kart from are out of town in Socal this whole week and I cant talk to them till Monday or Tuesday next week . Time is ticking, getting antsy already....
              Well, I was going to IM you on AIM, but you signed off. Now, when I'm typing this you signed back on. C'mon, are you on or off? :D I'll send you a link *now* (submitted..)
              • BDSax
                Junkyard King
                • Mar 2006
                • 3594
                i guess you got some good flexing going on that kart..............
                i remember when i raced karts, some rookie dumbass spun in a turn and didnt move, he was right in the groove. i hit him coming right out of the turn. i bent the front right of the frame big time
                • Justin B
                  Sikky Nar Nar
                  • Mar 2005
                  • 4273
                  Yeah, you could say that frame has a little extra aftermarket flex dialed into it. Not exactly the optimal kind though either ;)
                  I work at a karting school, and I've seen my fair share of wrecks. One of the best ones so far (from work) was in an arrive and drive series race. The first of the year actually. The track configuration was such that there was a straightaway, that turns sharp slightly uphill and into an S turn. Someone spun at the bottom, and another guy ran into him, flying through the air, cruising over a short tire barrier and hitting a fence (off the ground) about 10 feet back. He landed upside down but somehow was OK, but the frame was a total loss, it didnt crack but bent the front end up on one of the sides, and the whole length of the chassis into a taco shape by about 2-3". As I recall, it didnt even bend the rear axle though, amazing =x
                  • BDSax
                    Junkyard King
                    • Mar 2006
                    • 3594
                    hahaha, i sure did have my share of wrecks. i was at an arrive and drive not to long ago and some one did finish turning and just kept going striaght and jumped the hill and went crashing into the fence.
                    it was pretty funny to watch
                    • BDSax
                      Junkyard King
                      • Mar 2006
                      • 3594
                      BTW he was ok
                      • e304me
                        • Feb 2006
                        • 1374
                        My last race i had some one decide not to brake for the corner and instead hit me so hard it bent my axle and ended my day
                        • Justin B
                          Sikky Nar Nar
                          • Mar 2005
                          • 4273
                          Yeah, double duty braking is no fun..I know about that too :) It can be a pretty rough sport
                          • TheB1G Lebowski
                            • 593
                            Damn i wish we had that in the carolinas. :(
                            1989 325i - sold
                            1987 RX-7 Turbo II - sold
                            1990 325i
                            • Omaliyo
                              • 243
                              rah roh noob bumping a old thread lmao
                              Slamburglars Handbook:
                              5. Slamburglars don't get stuck on speed bumps, speed bumps get stuck on Slamburglars
