This Is Pictures.
  • KenC
    King of Kegstands
    • 14396
    #15871
    Are you certain the wheel wasn't broken in the collision?
    Originally posted by Gruelius
    • Bglad
      • Jul 2010
      • 562
      #15872
      Originally posted by TG Goose
      my guess is she was finger banging herself, and rear ended the car.
      ^^^This
      • Texas Toast
        • Jan 2011
        • 510
        #15873
        The only time I've seen XXR break like that is in a collision. Plus even if it was from a crack its her own damn fault for not replacing it. I wouldn't trust any brand wheel that has a crack running across one of the spokes.Their XXR for christs sake, not like they're expensive.
        Wrecking cars, closing bars.
        Tie rod spacers for sale: http://www.r3vlimited.com/board/showthread.php?t=245785
        • PNWDan
          • Feb 2011
          • 1326
          #15874
          As much as I agree that XXRs aren't the best wheel, there is something completely bogus about that thread. I have seen wheels break at the spokes while the car is in motion. The entire outer rim and tire leave the car. The fact that the rubber is still there suggests it was an impact that caused it. Im inclined to think maybe it was a flat tire and she panicked. Either way I highly doubt this wheel just broke without some sort of abuse. The missing lug nut suggest a lack of care to begin with.
          There are a lot of wheels on the market that are cast aluminum just like XXR. Most after market ones you see are. You see them on 6000 lb SUVs and 7000 lb trucks.
          1987 Alpinweiß 325is
          Like the PNW E30 Local Crew Facebook page
          • Mr. Tasty
            • Jul 2011
            • 3421
            #15875
            yea, that story seems so fishy.
            2014 Alpine White 335i MSport
            (Daily Driver)
            Full Mperformance Aero
            KW V2 Coilovers
            VRSF Catless Downpipes
            • Joe G
              • 2947
              #15876
              Someone with ~$1000 to blow needs to buy a set of them, and a $500 car and hit every pothole he can find at 70mph. Then we will know if this is even reasonably plausible.
              Current Car: 2011 BMW 135i, M-Sport, 6 speed
              Originally posted by lambo
              Sounds like you need a massage.
              Originally posted by kpeng
              Who the hell is Vlad?
              • dannyyisntt
                • 3141
                #15877
                Originally posted by Deltron Dirty30
                Here is a repost from another forum:
                My FRIEND bought these wheels to use for the winter with snow tires. She bought them NEW-used
                How about reposting pictures of the SHE in this story :pimp:
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  #15878
                  it honestly doesn't make sense if you think about it. It either didn't happen, or it did happen with previously damaged rims.
                  (Daily Driver)
                  KW V2 Coilovers
                  • KenC
                    King of Kegstands
                    • 14396
                    #15879
                    Not to mention that the broken spokes are in the direction of the collision.
                    This is some CSI shit up in here! lol
                    • Fusion
                      • Nov 2009
                      • 3659
                      #15880
                      There are round scratches around the centers. The wheel was intact and able to turn and get symmetrically scratched by something.
                      = wheel broke on impact, not causing it. Or someone just hit it with a hammer at the junk yard, because all the pieces are there.
                      • akorcovelos
                        • Dec 2006
                        • 1149
                        #15881
                        Also funny how the two broken spokes are facing forward directly in line with the impact.
                        2012 MCSCC/NSSCC CP class champ
                        HSAX Instructor
                        • chadthestampede
                          • Jul 2008
                          • 3601
                          #15882
                          just god trying to rid us of an evo owner
                          Originally posted by LJ851
                          Feedback
                          • sam3
                            • May 2007
                            • 206
                            #15883
                            In the picture that shows the entire wheel,the rim immediately outside the broken spokes is bent toward the hub beyond what would occur if the wheel had simply broken, indicating it was damaged by impact with something which intruded into the rim diameter more than a flat surface (i.e.the road). Also, a wheel can't "collapse" unless all of the spokes are broken, breaking the spokes under compression will just transfer the load to the spokes under tension and vice versa. I suspect the driver just had a blowout and the wheel was damaged by impact, probably with a curb.
                            • Holland
                              • Nov 2008
                              • 7212
                              #15884
                              Originally posted by sam3
                              In the picture that shows the entire wheel,the rim immediately outside the broken spokes is bent toward the hub beyond what would occur if the wheel had simply broken, indicating it was damaged by impact with something which intruded into the rim diameter more than a flat surface (i.e.the road). Also, a wheel can "collapse" unless all of the spokes are broken, breaking the spokes under compression will just transfer the load to the spokes under tension and vice versa. I suspect the driver just had a blowout and the wheel was damaged by impact, probably with a curb.
                              Looks like this was...
                              Blown out of proportion.
                              Originally posted by DEV0 E30
                              • Texas Toast
                                • Jan 2011
                                • 510
                                #15885
                                ^fucking win hahaha
