ok thats it, deltron, you are GAY. you own a pink fucking miata? you do the cat daddy? you wear pink? all at the same time? i'm quite frankly surprised there isn't a pink dildo in your ass, or atleast i hope not.
seriously, you must love it when people call you a fag or something.
Yamaha designed the 2ZZ-GEs VVTIL motor "built by Toyota"
Sold to Lotus..
Toyota commissioned Yamaha to design the 2ZZ-GE based on Toyota's ZZ block and the engine is similar to a typical street bike engine, in that it utilizes a nearly square stroke ratio allowing for high-RPM operation and producing a power peak near the top of the RPM range. The high-output cam profile is not activated until approximately 6,200 rpm and will not engage until the engine has reached at least 60° celsius (140° fahrenheit). The Toyota PCM electronically limits RPM to about 8200 RPM via fuel and/or spark cut. The "lift" engagement and the engine redline vary by application. Lotus 2ZZ-GEs are rev limited to 8500 RPM, for example, whereas Celicas were rev limited to 7900 to 8200 RPM in North America, depending on the model year. The first Japanese versions were rev limited to 8600 rpm with a peak of 190 hp. Consequently, it is impossible to "over-rev" the engine with the throttle alone; a downshift from a higher gear must be involved. A typical "over-rev" can damage the oil pump, commonly disintegrating the lobe ring, resulting in damage similar to the picture at right. The oil pump is the Achilles heel of the 2ZZ, though incidents are rare and usually occur due to fault of the driver. Even the briefest period of oil starvation is usually fatal to this engine design.
>implying i am white
YAMAHA AMI
"This car was released 600 limited from YAMAHA in Japan. this is based on DAIHATSU OPTI..
all outside body panels are FRP. body frame has been strengthened by roll cage."
Why you mad though?
