This Is Pictures.
  • slammin.e28
    שמע ישראל
    • 12054
    #18901
    Originally posted by JasonC
    For a state thats for Lovers!, yes you are lol.
    So I guess we get the ones in the green circle...
    • slammin.e28
      שמע ישראל
      • 12054
      #18902
      • u3b3rg33k
        • Jan 2010
        • 2452
        #18903
        Originally posted by u3b3rg33k
        530hp / 465lbs/ft - will not meet emission standards - rough idle / 7500
        TOTAL upgrade with engine rebuild - - $ 45,694.00
        Originally posted by Pantless Spency
        would be so fun to drive tho....
        i wonder how a twin turbo stock internals one would fair against the modded one....
        Well, a modern, BMW (w/vanos) twin turbo 48V engine:
        Nominal output hp/rpm
        535/5250-6000
        Max. torque lb-ft/rpm
        550/1500-5000
        5HP difference. 24 valves difference. I'm sure the newer one would be faster in the same car (torque is nice and all that), but still. imagine what that would sound like with a track friendly exhaust?
        It's probably the closest thing to an S70/2 that you could practically get. Unless you get a newer, built up NA BMW V12. but still $$$$$$$$$$$$
        some light reading:
        [Gordon Murray's] creation was the fastest production car for almost a decade when it was surpassed by Bugatti Veyron, Koenigsegg CCR and SSC Ultimate Aero TT. However, unlike forced induction (turbo or supercharged) cars mentioned above, the F1 is still the fastest production car with a naturally aspirated engine which was unsurprisingly made by BMW.
        “The Veyron because of its high CDA figure and huge cooling drag needs 1001 hp to go 12 mph faster than a McLaren F1 producing 627 hp. To help understand the problem of starting a car program from a weak point aerodynamically, we do some calculations: A turbocharged F1 producing 1001 hp would achieve 281 mph assuming the same drivetrain efficiency. Another way of looking at this equation is that an F1 would need “only” 740 hp to reach the Bugatti’s top speed. All this demonstrates just what an uphill struggle the Bugatti team faced to achieve their targets.”
        Gordon Murray
        Ich gehöre nicht zur Baader-Meinhof Gruppe
        Originally posted by Top Gear
        Just imagine waking up and remembering you're Mexican.
        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
        • dcboy
          • 21
          #18904
          You forgot the best one...
          • slammin.e28
            שמע ישראל
            • 12054
            #18905
            • BlackbirdM3
              • 2766
              #18906
              535/5250-6000
              550/1500-5000
              some light reading:
              http://www.bmwblog.com/2009/06/28/bu...-incomparable/
              I'll see your glowing exhaust and raise you a hotter glowing exhaust. Cool pic by the way ;)
              I will say that the sound of pretty much any V12 is music to my ears.
              Will
              '88 BMW M3
              • george graves
                • 19986
                #18907
                Originally posted by Matt-B
                • CHIF8008
                  • 3447
                  #18908
                  needs to be next to the real deal
                  -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                  -The Beauty in the Tragedy-
                  MECHANIC SMASH!!- (you all know you do it)
                  Got Drop?? ;-)
                  But of course
                  E30s are know to be notoriously really really really ridiculously good looking
                  • Massimo
                    • Jan 2008
                    • 3207
                    #18909
                    Those are crazy, but TBH, I think I'd rather have a built NA V12. I don't think I'd know what to do with that kind of torque (in an e30).
                    6.0 LITER UPGRADES
                    This package is a continuation of the complete rebuild of the engine with the upgrade to 6 liters. The 6 liter parts change the stroke of the engine from 75mm to 86mm, the bore from 84mm to 86mm and the compression ratio from 8.8/1 to 10/1.
                    OPTION E
                    530hp / 465lbs/ft - will not meet emission standards - rough idle / 7500 redline
                    custom billet crankshaft - 86mm stroke
                    custom steel connecting rods
                    11.0/1 pistons or higher
                    custom roller cams - redline of 7200 rpm
                    roller cam conversion for M70
                    high performance valve springs
                    titanium valve spring retainers
                    larger intake valves (43.5 vs 42)
                    larger exhaust valves (37 vs 36)
                    port and polish cylinder heads
                    match port intake gaskets
                    custom intake system - indv. runner
                    Electromotive engine management system
                    custom headers w/ceramic coatings
                    fuel injectors
                    crank gear kit
                    head gaskets (Csi)
                    dyno - break in, tuning, map fuel & timing, burn custom chip set
                    Maybe if we do a group buy, they'll throw us some M20 roller cams (lol)
                    I would keep the 75mm stroke and got with a billet crank. Pushing her up to 10,000rpm
                    Should be good for about 850hp
                    • u3b3rg33k
                      • Jan 2010
                      • 2452
                      #18910
                      I see what you did there, BlackbirdM3. Talk about a truly epic engine...
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #18911
                        Lets hope that they at least change to a double-row timing chain...
                        • gooseadrian
                          • Aug 2011
                          • 284
                          #18912
                          I hate cars with camber! I just cant see how this looks good. Even slight camber looks horrible to me, IMO...Discuss.
                          Fuck you buddy
                          • Dermeister3
                            • 1184
                            #18913
                            This thread is titled "This Is Pictures." Thus, we shall not discuss, unless it's with other pictures.
                            Hence:
                            • u3b3rg33k
                              • Jan 2010
                              • 2452
                              #18914
                              Funny - I remember reading a very convincing argument for going TO a single row timing chain.
                              EDIT: not what I was looking for, but: http://www.iemotorsport.com/bmw/E21-...2timchain.html
                              • MAXELHOFF
                                • Jan 2008
                                • 414
                                #18915
                                grain of salt:p
                                http://https://youtu.be/H8gOAzYchAE:ot:
