This Is Pictures.
  • MonkeyMadness
    • 3251
    #13831
    Originally posted by Ral
    I had some friends on the E there.
    That ship I think was the USS independence, one of two new designs for a new class of ship called the LCS.
    Really hope I don't have to land on the big E
    Dude, I've been on alot of shippes and the big "E" isn't that bad...
    Could be worse, you could end up on the belleau wood... ha ha
    • DatUtahGuy
      • Jan 2007
      • 3146
      #13832
      because artcar
      YOUTUBE: AR Perez
      If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
      • E30Kaiser
        • Mar 2008
        • 1790
        #13833
        Originally posted by Fusion
        Wow. I would have a weird feeling being in the water at the same moment as that bastard.
        I feel inadequate sometimes too... :(
        "We're not here for a long time, we're here for a good time"-Colin McCrae
        • DuMa
          • 1101
          #13834
          • dannyyisntt
            • 3141
            #13835
            Originally posted by Schwarz3
            because artcar
            Because aardvark?
            • JasonC
              Site Manager
              • 14451
              #13836
              1992 BMW 325iC
              1978 Chevrolet Monte Carlo
              • deutschman
                • May 2008
                • 5958
                #13837
                Originally posted by Deltron Dirty30
                • akorcovelos
                  • Dec 2006
                  • 1149
                  #13838
                  my company designed and built the propulsions gear drive for that ship. IIRC the hull was built from steel reclaimed from the Twin Towers.
                  2012 MCSCC/NSSCC CP class champ
                  HSAX Instructor
                  • ReallyDirtyThirty
                    • Jul 2010
                    • 449
                    #13839
                    www.truegearhead.com
                    - bad decisions & questionable cars
                    • Danny
                      • 14216
                      #13840
                      LOL what
                      • ReallyDirtyThirty
                        • Jul 2010
                        • 449
                        #13841
                        This overpowered brute was originally designed by Bob Norwood for NHRA drag racing. The car ran under the national class record with 7.0’s at 170mph in the quarter mile until its gigantic Vortech-like centrifugal supercharger was outlawed by the NHRA. At this point the car ran a few exhibition drag races and then arrived at Bonneville in 1989 ready to take a massive ram at the world of top-speed racing.
                        Essentially, the car was a tube frame Ferrari 308 designed for Pro-Stock drag racing and fitted with funnycar-type composite body panels. The rear tires were massive slicks mounted on a narrowed Ford nine-inch rear axle—exactly like present-day Pro-stock drag machines. The transmission was a pressure-shifted Lenco unit with nine-inch gears. The front-mounted powerplant was an evil-looking thing surely smuggled into Texas directly from Hell you might guess ran on Plutonium waste or Di-lithium crystals or something much worse. Actually, the 308’s engine ran on 120-octane super-premium race gasoline and was based on a Flat-12 Ferrari Boxer block fitted with 4-valve Testarossa heads, topped with a beautifully sculpted and truly massive air-water intercooler mounted directly on top of the block. The intercooler featured 12 super-high-flow electronic injectors spraying furiously into velocity stacks integral to the intercooler. The massive intercooler unit bolted directly to the heads and functioned as a combination intake plenum/intercooler/fuel rail/manifold unit.
                        The centrifugal blower—salvaged from a gigantic British locomotive engine that apparently no longer Thought It Could—was driven by a 1.5-inch shaft that traversed the length of the engine and was driven off the flywheel via a reversed Allison turbine helicopter gear-reduction unit originally designed to step down turbine velocities to something the main rotor could handle. The FAA required this type of gear reduction to be replaced after even a single emergency auto-rotation power-off landing, guaranteeing availability at fire-sale prices. The blower, looking like a hugely-overgrown Vortech blower sent back in time by The Machines to destroy all human life in 1989, had a five-inch impeller that was capable of gobbling air at the rate of something like 500 pounds per minute, a rate that could probably suck the air out of double-wide in less than 60 seconds!
                        The supercharged 12-cylinder Boxer engine, featuring a lightened flywheel and knife-edged crank, and could rev from the engine’s 1200 RPM idle to the 9K redline in just over a tenth of a second, and had been certified on a Superflow 901 engine dyno to make 1400 horsepower on 120-octane gasoline at 60psi boost. The short-stroke 3.2-inch bore engine was upgraded with a billet Crower crankshaft, extra-long Crower rods, custom forged pistons, and was managed by a Haltech F3 EFI controller and a Firepower direct-fire 12-coil ignition. According to Norwood, each 24-valve head was carefully flowed and mildly ported for optimum forced breathing.
                        In 1989, the flat-12 308 arrived out west in time to make a few runs in Land Speed Record country with Greg Johnson at the wheel. However, before the car got a chance to break the 223 mph record for 5.0L and less blown modified sports cars (1400 horsepower should’ve made this look easy, assuming the car hadn’t already entered a low earth orbit) the event was rained out.
                        “This may have been a good thing,” allows Norwood.
                        • JTDay
                          • Dec 2009
                          • 521
                          #13842
                          Past: 1987 325iS, Bilsteins - HR Sports
                          Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
                          2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
                          • JTDay
                            • Dec 2009
                            • 521
                            #13843
                            Originally posted by JasonC
                            thats pretty funny. i counter you with this...
                            • Dermeister3
                              • 1184
                              #13844
                              Originally posted by zebrafantastic
                              Don't fuck with BMW Marketers.
                              • alB5
                                • 785
                                #13845
                                Although bmw still sucks at commercials (besides that 1m one). Audi is far more creative when it comes to marketing in a whole.
                                But don't get me wrong, i still love BMW and VAG.
                                1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
                                No E30 Club
