A plane on a runway, how smart is r3vlimited?
  • E30 Wagen
    #136
    Originally posted by Justin B
    You're still thinking it acts like a car. If it is in neutral, the jet will push the car forward. Even if it was slowly, the conveyor would have to be moving at ridiculous speeds to cancel out the propulsion of the jet itself through the drag of the drivetrain in neutral. Unless thats what you mean, which would have to be the case to keep the car still.
    That is what i mean and I realize the conveyor belt would have to moving at rediculous speeds. That's why it was fun to picture Jordan's e30 on it. The problem says that the conveyor belt will match the speed of the plane, which is generated by the propulsion of the jet.
    • BENdashdash
      Tom is not my friend
      • Aug 2004
      • 2506
      #137
      Ben, did you read anything?
      no, dont have to. if the plane is thrusted by jet(s) and the conveyer belt will match the thrust, there is no way it would move, let alone lift. you guys are just overthinking this way too much. same if one were to try and push the plane while standing on the belt, it wouldnt move.
      • RCWells
        • 3589
        #138
        Alrighty, aside from the fact that there are now motherfuckin' snakes on the plane and we all know that opens up a whole new set of problems, let's get back to the original text. It states that the belt matches the speed of the plane, NOT the thrust of the plane. You are underthinking this whole thing.
        [THE 501 club - Founding Member]
        • Justin B
          Sikky Nar Nar
          • Mar 2005
          • 4273
          #139
          E30 Wagon, gotcha :). I understand, and yes that would be funny.
          Ben, the wheels on the bottom of the plane are relatively free rolling. The plane will go forwards relative to the ground beside the conveyor belt, while the conveyor belt goes backwards, the wheels just spin twice as fast as they need to. Maybe a little extra thrust to get over the slight drag created by the faster wheels. I understand your position if you didnt read anything, I thought the same way till it finally clicked.
          Edit -
          lol. thank you.
          • BENdashdash
            • Aug 2004
            • 2506
            #140
            answer me this. how can the plane move if the belt is moving as fast as the plane is?
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              #141
              The wheels are free wheeling. Thats not where the plane gets the thrust and forward movement from. Its from the jets, once again, if the conveyor belt is moving backwards, and the plane has thrust going forwards, the wheels will be spinning out from underneath the plane, then the thrust from the jets will overcome the little bit of extra resistance (which isnt even in the theoretical problem at the beginning of the thread) from the rearward movement of the belt, but most importantly, push the plane forward as well. The belt will only go backwards as fast as the plane advances FORWARDs in relation to the ground beside the belt. The length of this belt would have to be at least as long or longer than a normal runway.
              Am I going to be a lifer just from post counts explaining this to people? :crazy:
              • BENdashdash
                • Aug 2004
                • 2506
                #142
                doesnt matter what the plane is being propelled by. heck, you can even push it. the belt will match that speed, thus causing the plane to go nowhere. simple as that.
                /thread
                • James Crivellone
                  Head Janitor
                  • 6305
                  #143
                  • Axxe
                    • Aug 2004
                    • 3355
                    #144
                    That GIF is wrong. The conveyer doesn't apply any force on the plane directly, just through the wheels, which can be assumed as frictionless.
                    Keep it slideways!!
                    • Justin B
                      Sikky Nar Nar
                      • Mar 2005
                      • 4273
                      #145
                      We already seem to have gone over that a million times...
                      • Justin B
                        Sikky Nar Nar
                        • Mar 2005
                        • 4273
                        #146
                        lmao. You guys have no idea what you're talking about. Sorry. but I've explained this in detail probably 5 times already now. Nice animation though James, funny. Thats a way to look at it, but it is NOT what the question asks. I am not over thinking this, you guys just fail to look at the glaringly obvious detail. You're going to need that belt to go thousands of miles per hour, ASSUMING the wheels can hold up to it (they wont), to make the drag on the wheel bearings high enough that the jet cannot possibly overcome the drag of some bearings. WTF? Of course thats ridiculous. Its probably next to impossible anyway. Do yourselves a favor and look t the original post if you're going to spend time drawing, or even trying to find an animated GIF like that and look at those words "This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in opposite direction)." Hmm. Is that plane moving in that picture or in either one of your thoughts?? Not quite. Obviously you overlooked the whole point of the question. Its a trick, people will think like you guys and get all flustered and think people ho figured it out are morons, when infact you just need to open up your eyes :) The plane is moving forward as fast as the conveyor is going backwards, for the 100 billionth time, the wheels free spin, its not a damn car. Even if it was, worded in the same way, the car will still go forward since the question requires movement. The wheels will just spin twice as fast as the plane is vs the ground outside the belt. Its the belt moving backwards + the same speed of the plane moving forwards by the thrust of the JETS NOT THE WHEELS. Oy. Planes dont go forward by driving their wheels on the ground then once theyre in the air kick on their engines... lOL
                        Edit - Even if they did, which they dont, obviously, it would still work. Plane moves forward in relation to ground, belt moves backwards at that same speed, wheels think the plane is going twice as fast as it really is.
                        • george graves
                          • 20003
                          #147
                          Originally posted by James Crivellone
                          HAHAHAHAHAHH!
                          Originally posted by Matt-B
                          • dirty30
                            • 3124
                            #148
                            what if you take a sailboat, then put a huge fan on the boat and aim it at the sail... then turn it on.... will it move the boat?
                            • BENdashdash
                              • Aug 2004
                              • 2506
                              #149
                              justin, at first i was with you on this one. you know, trying to find an explanation to counter the obvious. turns out, there is no such thing. belt will match the speed of the plane, and thats all there is to it.
                              • Justin B
                                Sikky Nar Nar
                                • Mar 2005
                                • 4273
                                #150
                                Ben, it will not. I'll just leave it at that this time around. I am really tempted to write the whole thing over again, but I wont even mention why it'll move.
