Okay, so let's put a compression scale in between the skateboard and your hand (which is holding it from behind). Unless the wheel bearings are really crappy, I doubt that the measured force will be significant. The most important point to remember is that the treadmill is moving and the skateboard isn't, which of course means we have breached the requirements of the problem. However, let's say that we take our hand and push the skateboard forward at the same rate the treadmill is going in the opposite direction. Of course the scale will compress more and record a higher value, but again I believe that number will be a very small increase. This small increase in force is equivelant to extra amount of thrust required of the plane's propellers in order for it to move foward. The skateboard problem illustrates that if we set the amount of thrust of the plane's propeller to a constant value, and the speed of the moving runway high enough, then the plane could stand still for the amount of friction of the wheel bearings is too great for the thrust of teh plane's propeller to overcome. Again however, this does not satisfy the requirements of the problem for the speed of the plane and the speed of the belt are not equal.
wheel size has nothing to do with it, unless you consider that a bigger wheel adds more weight to the plane itself. However, this means that the wheel will spin slower, decreasing friction. I bet that a perfect ration of wheel size to wheel weight could be discovered to optimize the least amount of drag. I maintain:
Remember, you can't really say that the conveyor belt has a "backward thrust." This equivocates the force of the plane's propellers, or jet engines or whatever, with the force of the belt, which is not what the problem advocates. I made that same mistake too until I reread the problem a couple more times. Anyway, consider how heavy a 747 is. For it to even take off on stationary ground, I imagine that the wheel bearings on that plane are extremely efficient, and the jet engines extremely powerful. I suppose that if you take a plane from the middle of the century, it would struggle, but with today's airplanes, I'm confident that many could do without much increased effort of the plane's engines.
Just thought of another example that might help explain. Actually, I know it works to explain this because I think many of us have seen this i real life:
The conveyor belt would be like a big trailer that you would tow with a truck. Without the trailer, the engine can run at a lower RPM because there is no resistence (weight from the trailer). However, when you're towing a trailer, the truck's engine has to work harder and run at a higher RPM in order to maintain the same speed as it did without the trailer.
edit: ^that example isn't a good one, ignore it.
If you read some of my posts you would understand that there is alot more to just saying.. "Oh the jet flys with air speed and the wheels are not relative." which is completely wrong.
What I had discussed is that in the real world the weight of the plane, the amount of possible thrust, and wheels size would play a significant roll. The question is not HOW a plane is able to fly the questions is will it take off.
And again, I am sure that the increased friction of the spinning wheels is next to nothing and that we could throttle the propeller up to a higher RPM and the plane will be able to get up to speed enough to take off.
The conclusion is that if the plane is properly built and balanced with enough thrust to overcome the backward thrust of the conveyor it could fly. My second conclusion is that there are very few or maybe no planes built that could overcome this feat.
