What's the best medicine against sunbirn itch!?
  • Jean
    • 18228
    What is THE BEST course of actions to take to get rid of the sunburn itch ? It's driving me absolutely insane, I am ready to punch anything and everything in my view.
    I just googled a bunch of pages, does Vinegar really work ? I got sunburned really bad on saturday, and it was barable last night but today it's worse, the itch is terrible. I tried Sour Cream, tried Aloe Vera cream, just bought Aveeno Daily Moisturizing Lotion with Colloidal oatmeal to try...
  • gazellebeigem3
    • Jun 2005
    • 3712
    walk it off
    • 325Projectz
      • Jan 2005
      • 1956
      put some 'tussin on it.
      91 m3
      • JPL
        • May 2005
        • 774
        fresh urine works if you are tight on money.
        if you're not then get some lotion with cortisone in it. its a steroid so pump some iron while the effect lasts.
        also if you drink your own urine it gives you the same boost as the steroid because you recycle the testosterone your body naturally produces. body builders call it "doubling up".
        or rub your back on your rusted old exhaust.
        Originally posted by Hawt drift chick
        Yeah, i'm a good dude i swear, i just like to be balls to the wall.
        • Teaguer
          • Sep 2004
          • 6167
          Originally posted by gazellebeigem3
          walk it off
          Werd . Don't be puss Jean , suck it up .
          • Charlie
            kid tested, administrator approved
            • 6686
            Rub some dirt in it, Tiger.
            -Charlie
            Swing wild, brake later, don't apologize.
            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
            FYYFF
            • Jean
              • 18228
              LOL, I am not the person who takes even painkillers at the slightest opportunity but this shit sucks balls.
              • Jscotty
                • Jan 2007
                • 2285
                "scratch" it with a harsh deodorant soap (like dial or safeguard) and a warm wet washcloth until the itching goes away. Make the washcloth very wet and very soapy so that you can keep scrubbing the itch without damaging your skin. The chemicals in the deodorant soap will temporaily numb the nerve endings that cause your skin to itch. Afterwards, rinse your arm throughly and then apply rubbing alcohol to the surface. Do not touch the affected area for the next 5 to 10 minutes giving time for the alcohol to set in.. If the itching persists, repeat the process only once. Afterwards try another remedy.
                • Vedubin01
                  • Jun 2006
                  • 5852
                  the tanic acid found in tea works well. Just take a bath in tea!
                  • s0urce
                    • Dec 2004
                    • 2933
                    tomato soup bath, it works for when you get sprayed by skunks...I would assume it cures this too.
                    tasty
                    • Maluco
                      • Oct 2005
                      • 6572
                      make sure to post what ended up working the best... I remember I once burnt my back and upon applying lotion to my back it started itching like (@#$%@#(*#$% crazy. I was losing my mind it was so bad. I suffered for a while before chewing down two tylenols I think. All I really remember though is that is sucked extremely bad. It wasn't a burn, it was an insane constant itch that would not stop.
                      • bmancrash
                        • Feb 2007
                        • 11
                        Vinegar only works to take away the sting. Wont help the itch.
                        • StereoInstaller1
                          GAS
                          • 22679
                          Look carefully at the Aloe cream you bought. Most are less than 10% Aloe.
                          Go to your local health food store. Buy a bar of Original "Kiss My Face" brand soap, shower, then use 100% pure aloe gel.
                          The Aloe is available at Trader Joes if you have a hard time finding it.
                          Luke <burns by moonlight...indoor man!
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • bimmer8604
                            • 3017
                            dont use the dial bar soap. get some johnsons baby wash, and use that with a very soft cloth and warm water. then when you get out, put on the vaseline. trust me, i had 2nd degree burns on my face, arms, and hands. after 2 weeks of that, nobody could tell what happened. imagine what it would do on just a sunburn. try it!
                            kyle
                            1988 M3, 97 840, 99 XJ
                            DILLIGAF
                            • Jand3rson
                              • 37587
                              You need 100&#37; real Aloe Vera. Go an buy an Aloe Vera plant, and when you get a sunburn, cut off one of the leaves and break it in half.
                              Or do it the easy way and just go buy a bottle.
