Help with simple home wiring
  • Mike325
    • Mar 2006
    • 3685
    I am trying to wire up a momentary switch and a small light using 120v hose current. I have a plug, and when I connect the two wires off the plug to the switch, it sparts and the fues in the house wants to trip (I stop it before it does). This is what I have.
    http://www.radioshack.com/product/in...entPage=search
    The rest is just a plug and the light. Why is this sparking when connected and shit?
    Thanks.
    Originally posted by Kershaw
  • thectrlguy
    • Apr 2007
    • 1042
    What kind of lamp? And how did you wire it?
    Should look like this (I in no way take responsibility for this information, please consult with your local electrician, as they are qualified to perform this type of work - ***standard disclaimers apply***)
    The datasheet on that switch, said it's only good for 0.5Amps, that's not exactly a lot of current.
    • AndrewBird
      The Mad Scientist
      • 11892
      That switch is normally closed. I.E. - It is in the "On" position without pressing the button. Are you hooking just the switch to the outlet?
      • atomic
        • Jun 2007
        • 5691
        damn trying to burn your house down ?? Not trying to be a jackass here but why not just buy a lamp that works in your situation ??? just asking
        • Mike325
          • Mar 2006
          • 3685
          Ya, pretty much. I know, I suck at the wiring.
          • Cooper
            • Jan 2007
            • 99
            • ivo316
              • Oct 2006
              • 1222
              Ok, just like the diagram posted by thectrlguy says.
              The switch goes in one of the wires, not on both, the point is that you cut and splice one of the two wires (preferably the negative), then place the switch there, when you open the switch you break the circuit and the electricity (which flows from one hole of the outlet to the other, powering anything in the way) will stop flowing.
              Good luck. ;)
              • Mike325
                • Mar 2006
                • 3685
                Sweet, I think that I am getting it now.
                Thanks.
                • StereoInstaller1
                  GAS
                  • 22679
                  If your first post is correct, you are making a dead short!
                  Pay close attention to the diagram posted, see how one wire connects to the bulb directly, then only ONE wire goes to the switch, the other side of the switch then goes to the bulb?
                  You will get it....
                  Closing SOON!
                  Thanks for 10 years of fun!
