crazedlist.org
Tags: None
Been using it for a while now. Shaves hours off of my perusal of all the local CL's. Highly recommended.
MTech2 wheel | Husco Armrest | Smoked Hella Smileys | 5k HID | Stromung | RS003 | Shadowline | Amber Fogs | Too much else to list
I cant get it to work right. It just brings up all of the main pages in the cities I requested.__________________
1987 Toyota Landcruiser V8Comment
GOOD NEWS, NO MORE CRAIGSLIST HOMEPAGES FOR RESULTS!!
learn more -> if you're using the excellent web developer firefox extension then simply go to the disable menu and "Disable Referrers". if you don't have that extension you can go to the location bar in firefox and type "about:config" and hit return. there will be a window with a bunch of stuff, in the filter field type "sendrefer" this will reduce the big list to network.http.sendRefererHeader. click on that row, and change the 2 to 1 or 0 (1 will send the referrer to a site when you click on a link only, 0 will not send any referrer information -- thanks to brian for the about:config tip!). If you're using Opera you can alter this setting as well. in the location bar in type "opera:config", then type "referrer" in the search box, uncheck the enable referrer setting, and search like a madman! If you're using IE, delete it and use anything else ;)
Yeah, I saw that. I'm using Safari though.GOOD NEWS, NO MORE CRAIGSLIST HOMEPAGES FOR RESULTS!!
__________________
if you meant to type craigslist and somehow ended at this site, you are either psychic or a moron. this site is much nicer viewed in firefox, because IE is a piece of crap. © Copyright Andrew Payne 2005-2007
Add safari to the list....
I just tried it on Internet Explorer in Windows....No dice.__________________
What do ya know, it works in Firefox once you change the "2" to "1". Awesome.:mrgreen:__________________
