how much would u pay e28
    How much would you pay for a:
    1985 e28 535i
    270k
    bronzit
    black interior
    5 speed (wont go into 5th gear, hard to get into reverse)
    short shifter
    chipped
    e34 seats, power, heated
    e34 wheels with newish tires or m-contours with good tires
    replacements within the last year:
    -water pump
    -all belts
    -exhaust valve and adjuster
    -thermostat
    -heater core
    -fuel pump
    -fpr
    -injectors
    -afm
    The good:
    -engine stills pulls strong showing no signs of weakness, good compression
    -no clunks from the rear end (very common to have bad sub-frame -bushings/diff bushings)
    -modified air box (two 2 inch holes)
    -I will adjust the valves prior to sale
    -I will weld up the exhaust leak at buyers request (its not to bad but a piece of heat shielding needs to be cut away to get to the hole)
    The bad:
    -dash is cracked in many places
    -needs a transmission
    -rear seats faded
    -small hole in left drivers bolster
    -sunroof only pops up, wont open.
    -power locks don't work, all doors/trunk lock and unlock fine, just individually.
    So how much would you pay for it:
    as-is?
    replaced tranny?
    with m-contours w/ good tires?
    replaced tranny and m-contours?
    m106 1990 e30
    e36 daily
    e32 cruiser
    1300
    1400
    1500
    I dont know im just putting numbers up and bumping the thred up.
      $1.298.00 tops
        $900-$1200
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
          1985 325e 2.8 Turbo VEMS
            oh great, lol not the 27.50 thing...
            cool im glad to be hearing right around a grand, thats around what i would be asking for it.
            m106 1990 e30
            e36 daily
            e32 cruiser
              $800
              Rollin' with a Geistkuchen
                1k.... more would be dumb unless you had a parts car for the neededs
                PNW Crew
                90 m3
                06 m5
