Comuter hardware help!
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Sounds like the wrong part for the job. If it don't fit, it's not supposed to.
    • equate975
      • Jun 2004
      • 3382
      Razor blade
      Rollin' with a Geistkuchen
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        When your computer explodes, I'll lol.
        • s0urce
          • Dec 2004
          • 2933
          Wow...people giving you the advice to cut the ram are downright stupid. Please post the model# of your computer as well as the Model# for the ram.
          tasty
          • TDE30
            • 7042
            Use a hammer.
            - Trey
            E90 325i/6 (ZSP, ZPP, ZCW)
            E36 325i sedan
            E30 325i sedan
            Volvo 945T
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Thread CliffNotes
              "It does not fit, what should I do?"
              "Hack it up to void warranty or damage other components, I got the round peg in the square hole, you can do it too."
              • kronus
                • Apr 2008
                • 13032
                I don't think anyone told him to cut the RAM.
                From what I understand, the secondary RAM slot of his motherboard has a nub-thingy that is supposed to prevent RAM from being installed the wrong way. However, by being a ham-fisted buffoon or some other reason, he broke that nub-thingy and made it flatten out. What has been suggested is to cut the nub and fit the RAM in, making sure it's in the right way.
                Another thing you can do is take a pair of narrow needle-nose pliers, and squish it back into a shape that will not interfere with the RAM stick when it's being inserted.
                He did not get the wrong RAM, he got 2 of the same stick. The slots on the motherboard are the same style 99% of the time (the only exceptions I've seen are old Pentium I motherboards), so it's not an issue of the RAM being the wrong kind for the slot.
                cars beep boop
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  I was refering to hacking up a precision engineered motherboard component to install RAM, where obvious the fact is he wasn't skilled enough to take the time to install properly.
                  • kronus
                    • Apr 2008
                    • 13032
                    Well, your point is valid. However, this precision engineered motherboard component is supposed to prevent RAM from being inserted improperly. It seems that it failed at that, since the RAM can now be inserted partially, which is enough for someone to think that it's done, close everything up, and destroy their computer on the next start.
                    It's kind of like a clutch stop made out of a sponge.
                    Did you get my PM?
                    cars beep boop
                    • aworthybrother
                      • May 2007
                      • 899
                      How sure are you that you have the right RAM for your PC?....
                      Post a pic of the actual issue, you might get better help.
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        Did you get my PM?
                        I am awaiting a call for an interview this afternoon. Not sure what the trapperkeeper planner has in store for me ATM.
                        I'm just saying if you can't install it right, you shouldn't be trying. It sounds like DIY Arterial-Stint placement.
                        • kronus
                          • Apr 2008
                          • 13032
                          Roger that. Good luck
                          cars beep boop
