Question for all the computer nerds.
  • Money$hit
    • Mar 2008
    • 1604
    Ok, I have an issue at work
    I can remote into about 95% of our servers (remote desktop for windows, SSH tectia client for Solaris/HP/Linux or Symantec PC anywhere) from my desktop. The other 5% I can remote into, but cannot map my network drives, and these boxes all run Windows Server 2000.
    Short of loading the needed scripts, AV updates, programs onto a CD and going out onto the server room floor I cant do any work. Its difficult to do this because there are fucktons of servers, which arent labeled either. Ive spent hours searching for one or two boxes just to run a WSUS update or the like. Is there a way that I am just not seeing to map my network drives to these boxes?
  • James Crivellone
    Head Janitor
    • 6303
    Are they on a domain? Are they updating with LDAP correctly?, etc?
    • Money$hit
      • Mar 2008
      • 1604
      All different domains with different (but similar) protocols.
      • scabzzzz
        Estado de mierda de encargo
        • 6870
        Edit: I cant read this morning.
        What do you mean map your network drives? And what are you trying to do? I dont really understand.
        • Kruzen
          • Mar 2004
          • 5603
          can you get to them via \\ip\name$
          Who doesn't love a little BBQ?
          Griot's Garage at a Deep Discount
          • BimmerTom
            • 255
            When you log into the servers, are they any application log errors? More specifically, stating they can't contact a Global Catalog server for your domain? You mention these are servers across domains, which is why I am asking. You might just be logging in on cached credentials.
            Tom
            My new blog site: http://www.tomperso.com
            • Money$hit
              • Mar 2008
              • 1604
              nope, tried it.
              Usually when I remote in on the Remote Desktop tool, you can go into the options and check the option that lets you take with you your drives that you can access from your desktop.
              i.e. if you can access X:\ drive from your desktop, but not from the server you are remoting into, this gives you the option to kind of virtually "take the drive with you" into the server from your desktop.
              • gazellebeigem3
                • Jun 2005
                • 3712
                do you work at dscc? i know a pretty big nerd that works there that could probably help
                • e30vert
                  • Jan 2005
                  • 1789
                  Use WinMSG to send a message right to the screen that produces a popup that says - Hey, Where the fuck is this machine please call "insert your extention here"
                  The only problem with that is sometimes the pop up dialog boxes will not pop up over other windows or if the machine is a server and is locked. When it is unlocked by someone then they should see it.
                  • SamE30e
                    • Sep 2007
                    • 4319
                    /format c
                    1985 325e 2.8 Turbo VEMS
                    • James Crivellone
                      Head Janitor
                      • 6303
                      Tom
                      This is where I have my thought process at ^^^, def sounds like an ldap com issue if it cannot authenticate your SID with the GC.
                      • damith
                        • 422
                        Authenticating issue
                        ^^^^ sounds more like an authenticating issue to me.
                        [All the Bronzit haters]
                        • Charlie
                          kid tested, administrator approved
                          • 6686
                          Sounds like you should buy a mac.
                          -Charlie
                          Swing wild, brake later, don't apologize.
                          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                          FYYFF
                          • BimmerTom
                            • 255
                            F-that. Just run Linux. :)
                            Ubuntu 8.10 FTMFW
                            • Collin
                              • 1736
                              Hit alt+F5
                              The Keystone Killers
                              With 73k+ post, you'd think he'd have learned a little about life.
