In car video E30 M3 S38
  • Camber
    • Dec 2009
    • 5
    Camber
  • speedminded
    • 291
    Really strange to have two in-car videos playing at the same time but it's interesting to hear the totally different shift points...
    AUTOMOTIVE PHOTOGRAPHY │ JASONTBARKER.COM
    • e30esque
      • Jan 2008
      • 505
      Unbelievably sweet.
      • craz azn
        • 746
        Awesome cars. Any info and pictures of each car?
        Edit: Saw the link to the site at the end of the video. You used to have a crazy white e30 325 with a M20 w/ITBs right? I loved seeing that car duel with a Gr5 body M1 in one video I downloaded a few years ago.
        Rippin' Proper | Youtube | Vimeo |
        • jahnaboi
          • Oct 2006
          • 1742
          Ground the gears couple of times eh? Nice vid.
          EDIT: Thought you were the e30. Nvm. Lol. That sucks. Stupid car. Was than an Enzo?
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • Camber
            • Dec 2009
            • 5
            BMW E30 M3 S38
            Technical information
            Engine BMW M5 3.8 6-cylinder, 24 valve / S38B38
            Cylinderhead
            Cylinderhead flow / mm / hp / 7" flow
            2 mm 123,5
            3 mm 186,2
            4 mm 251,6
            6 mm 354,7
            8 mm 429,8
            10 mm 481,4
            11 mm 502,3
            12 mm 520,6 (201,8 CFM)
            14 mm 542,1
            15 mm 558,1
            Inlet valve 39,5 mm Schrick (steel)
            Exhaust valve 32,5 mm orginal (natrium)
            Massive cylinder head flow works
            Schrick valve spring / titanium retainer and lash cap
            S50B32 Cam follower
            Adjustment camgear
            Camsaft
            Schrick inlet cam
            308 degree / lift 12,2 mm
            Schrick exhaust cam
            296 degree / lift 11,7 mm
            Throttle body BMW M5 3.8 S38B38 50 mm
            Injector Bosch 420 cc / 5 bar
            Air filter ITG Megaflow special made
            ECU Haltec E11v2
            Ignition MSD 6 AL / distributor
            Exhaust manifold 6 – 2 – 1 Stainless steel. Secondary pipe (adjustment)
            Thermo coated
            Exhaust pipe Stainless steel plate (made by pipe) 3” and hand made mufflers
            Piston C.P.S Pistoni special, bore 94,6 mm (balanced)
            Connection rod Auto-Verdi, light (balanced, top end and big end)
            Cranksaft Orginal S38B38; balanced
            Oil system Orginal and bigger oil cooler
            Compression ratio 12:1
            Power 450 hp / 7030 rpm (exhaust manifold restricts max power)
            Torgue 480 Nm / 6100 rpm
            Torgue range 3000 rpm / 355 Nm / 4000-7000 rpm +430 Nm
            Flywheel Steel 4,0 kg
            Clutch Alcon 184 mm twin plate
            Gearbox Sport Getrag 265; factory Group-A race gear ratio and direct gear connection
            Differential 4, 27 / 75% limited slip
            Steering Fast steering 2,3 round to left-right
            Suspension
            Front axle
            BMW E36 up-right
            Öhlins 36HMRCW 2-way coil-over McPhersson strut
            Uniball top mounts including camber and height adjustment
            Anti-roll bar 34 mm steel (BMW M3 DTM) Dolate-Motorsport
            Front whisbone; adjustment and uniball connection
            Rear axle
            Öhlins HMR 350 3-way coil-over shock absorber
            Camber and toe adjustment trailing arms
            Uniball connection
            Brakes
            Front axle
            Alcon CR6380 monobloc
            Disc; 355/32 mm
            Caliper; 6-piston
            Rear axle
            Alcon caliber; 4-piston
            Disc; 330/28 mm
            Wheels
            ATS DTC 9 X 17”
            Body
            Carbon parts*
            front hood*
            rear hood*
            bumpers*
            doors*
            DTM front- and rear spoiler*
            lexan/polycarbonat front/rear side windows and rear window
            rollgage(18 mounting points)
            Sparco Corsa seats
            Sabelt safetybelts 6-mounting points
            Weight
            1130 kg whitout driver
            • tangkenboo2
              • Nov 2005
              • 799
              that was fun to watch.
              [PAKSIW]
              20D .........
              vmwerks :up:
              ryan gmw :up:
              • etxxz
                • Feb 2006
                • 2085
                poor f40... why did you hit it?... you bastard..
                kiddin, great video i love the side by side video and audio! very exiting, but wild driving. Give us a little info on your transmission linkage please.
                No more e30s for me.
                88 black BMW OBDII 332is dedicated track [sold]
                88 BMW OBDII bronzit 332is [RIP 03/08]
                91 BMW 325i [sold]
                86 Corolla 'Ae86' HB 20v trd [sold]
                http://youtube.com/watch?v=pTj7Hn9v5Rs
                • Wh33lhop
                  • 11705
                  Holy shit. I was going to make a comment about those pesky slow F40s but it looks like a kit car.
                  Regardless, that E30 is absolutely ridiculous. Looked like a hell of a lot of fun.
                  Just curious though, what are the factory-A ratios, and are gears 4 and 5 dog engagement or something? Didn't notice any clutch action when upshifting to the last two gears.
                  paint sucks
                  • E-Thirty
                    • 1331
                    More!!
                    Do you feel like something is trying to penetrate your butthole?
                    • craz azn
                      • 746
                      AFAIK there is no such thing as a Dog engagement Getrag 265, even the early Grp A DTM cars had synchromesh 'boxes.... Care to share the info on where you got it, or who designed/manufactured this? Thanks!
                      • JamesE30
                        • Feb 2007
                        • 2092
                        Holy fucking shit that was so fucking awesome! Really exciting to watch!
                        Sorry about the damage, looks like you came out better off than the f40
                        R.H.D
                        M-technic I club
                        • Wh33lhop
                          • 11705
                          Dogleg dogbox FTW?
                          Nice ride height even with the wheels off the ground :p Is the S38 bowing the CF hood or something? No subframe spacers?
                          paint sucks
                          • JamesE30
                            • Feb 2007
                            • 2092
                            Originally posted by Wh33lhop
                            Dogleg dogbox FTW?
                            Air pressure.
                            R.H.D
                            M-technic I club
                            • Camber
                              • Dec 2009
                              • 5
                              Hi!
                              I'm not actually sure what kind gearbox factory use a Group-A or DTM cars (synchromesh or they have dogbox) I think that time 1986-1992 is only syncromes race box.
                              Yes, my gearbox all moust dogleg "dogbox". I dont need to use clutch when i upshifting, i only do it "step up and down" gas pedal when i upshifting. I can down shift too whitout clutch but still i use clutch because i want to long life my gerabox.
                              There Finland is a my frends factory and they made a dogleg "dogbox" gear-ratios and inside steel shifthing fork etc.
                              Gearbox ratio:
                              1= 2.340
                              2= 1.680
                              3= 1.300
                              4= 1.138
                              5= 1.000
                              Camber
