GT4 Drifting
  • 92 mtechnic cabrio
    • 4907
    GT4 Drifting
    with Charlie's E30 spec skyline!
    sorry I'm not much of a video editing guy. I just wanted to get the video out there.
    R.I.P 07/01/09 - 04/23/10 :(
  • CGDoig
    • Nov 2005
    • 348
    what the fuck. Dude thats insane. I have no idea how you've gotten that good at GT4 other than playing it 24/7. But cool.
    '05 Jetta TDI
    '87 325iS: Facelift, Hella Smoked Ellipsoids (RIP)
    '80 320i: 500lbs lighter, Rally/Drifter (SOLD!:( )
    '90 Jetta: Stock Daily Driver (SOLD)
    • DarkWing6
      • Apr 2004
      • 7144
      that is awesome
      • bumblebeemer
        • Dec 2005
        • 224
        yea man that shit is hard to drift in that game. gt3 wasnt as hard but gt4 u spin like everytime u get a lil crocked. wat are ur settings for the r32?
        • dude8383
          • Jan 2005
          • 10387
          that was fuckin awesome
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            that's some good looking drifts you got there, you have too much time on your hands, i better get practicing!
            • Jand3rson
              • 37587
              Holy shit Jon, amazing run! That was flawless!
              Hell yes it was easier in GT3, I had an AE86 that Jordan set up for me, and an S2000 that I built, and I could drift the shit out of them! In GT4, I can't seem to replicate the settings I had on my S2K, it just won't drift the same. Post up your specs for the R32!
                • 4907
                1991 Skyline GTS-t Type-M :D 427hp
                Make sure you change the oil!
                Tires: Sport Soft all-around
                Get all the usual hop up parts, you basically want to max out the car.
                Nitrous if you like, keep it at 50.
                Driving aids all set to 0
                Brake Controller:
                F:4
                R:20
                Transmission: Auto Setting 9
                Suspension (The Most important)
                Spring Rate: F:9.2 R:7.8
                Ride Height: 100 all around
                Shock Bound&Rebound: F:8 R:6
                Camber: F:1.0 R:2.0
                Toe: -2 all around
                Stablizers: F:4 R:3
                LSD Full-Customize: (Next most important)
                18
                60
                5
                some general points for tuning any car for drift:
                - Don't make it such a stiff spring rate, it makes the car more twitchy, and give it the popular tendency to snap-oversteer
                - Softer in the rear than the front
                - LOCK the LSD, meaning 60 for the middle bar
                - Less brakes in the front so that there is less load on the front tires so you can enter a turn braking.
                also, there are several techniques I use:
                - heel-toe (yes, it can be done) just stay on the gas, and "blip" the clutch by tapping or sliding the bottom of your thumb across the circle.
                - e-brake - you can hear this A LOT in my video, it also kills the engine, like clutching in so you can.......
                - SHIFT LOCK! After you've e-braked, the clutch is engaged, so put it in a lower gear and slowly slide on the gas, this will make the gears engage in a different manner, and your car will start sliding outta nowhere!
                • nickmp0wer
                  • 1427
                  now try it with the wheel and without using the ebrake
                  • Jand3rson
                    • 37587
                    When I was drifting in GT3, I never used the ebrake. It was all gas, brake and weight distribution.
                    • Streetspec_iS
                      • 1622
                      nice. il try and get some vid of my s13 drifiting. it takes a while, but in the end drift in gt4 is actually better than 3.
                      the only thing that pisses me off in the replays is lack of tyre smoke, i wanna see plumes pumping out the back.
                      sigpicM42 Brigade ... Throwing craze in the 318
                        • 4907
                        I was using a steering wheel.
                        And I don't actually use the e-brake as much as I say I do. I'm just trying to encourage e-braking, because it's more than just a cheater's button, it can help lengthen slides and essentially "reset" your slide.
                        It's not that I'm trying to defend myself. There's nothing wrong with using the e-brake, all the pros do it, Ken Nomura, Keiichi Tsuchiya, Taniguchi, Kumakubo, Rod Millen, Ryan Hampton, the list goes on.
                        I mean, you don't want to get so dull by not using the e-brake that you end up just power sliding everywhere. If you notice in the video, I'm not even really on the throttle in half the slides.
                        • Streetspec_iS
                          • 1622
                          handbrake is used heaps in pro drifitng i dont know whhy people shun it as a 'soft' option. its what most of the guys use to get massive pre-entry.
                          • misterlance
                            • Nov 2005
                            • 170
                            Impressive gameplay. Now I have to go play.:borg:
                            • tonytony
                              Knee deep in poopie
                              • Jan 2004
                              • 3498
                              IMO i think gt4 drifting is way........ easier, i can drift with the csl like it was nothing maybe i just got luck with my settings, but in gt3 i only got a good drift 1 out of 5 tries with the trueno
