Engine bay picture request
  • Stephen
    Шлем ишака
    • 10774
    So, i searched but this kind of thing is hard to search for
    What would be great is a engine bay pic with location of certain parts pointed out
    like
    AFM
    ICV
    Thermostat housing
    FPR
    And anything else you need for a 2.7i :P
    Basically im trying to get parts and he wants to know what is where
  • kronus
    • Apr 2008
    • 13032
    gimme a min, I'll poke through the engine bay thread and get you a labeled pic
    cars beep boop
    • kronus
      • Apr 2008
      • 13032
      The t-stat housing is on the waterpump if I recall correctly, which is on the front of the engine block to the left of the diagnostic port. Your Bentley should be able to pinpoint it better.
      fixed in order to stop the spread of disinformation. used to say 'under the'
      cars beep boop
      • Stephen
        Шлем ишака
        • 10774
        Originally posted by kronus
        The t-stat housing is on the waterpump if I recall correctly, which is on the front of the engine block under the diagnostic port. Your Bentley should be able to pinpoint it better.
        Wow, thanks, was expecting to kinda have to pull teeth on that one.. i cant use my own engine bay pics cuz mines an eta :( [for now]
        • smonkbmw
          Professor
          • Jun 2006
          • 4549
          *bzzzz* wrong, thermostat housing is where the 2(3?) radiator hoses go into the motor.
          • Stephen
            Шлем ишака
            • 10774
            ohh, haha... Have a pic?
            • kronus
              • Apr 2008
              • 13032
              Which is the water pump, which is sort of under the diagnostic port. I'm not excruciatingly near my car right now, just had a look at my Bentley and realized I was somewhat wrong. Those hoses go into the water pump, which is below the FPR.
              cars beep boop
              • Stephen
                Шлем ишака
                • 10774
                If one of you guys could get a closeup, id be eternally grateful
                • smonkbmw
                  Professor
                  • Jun 2006
                  • 4549
                  k see where all the hoses are feeding into? the only part with out a bunch of numbers around it? the part without numbers on the right side of the pic.
                  http://www.realoem.com/bmw/showparts...68&hg=11&fg=35
                  and another pic of the actual part:
                  http://www.realoem.com/bmw/showparts...59&hg=11&fg=35
                  • Stephen
                    Шлем ишака
                    • 10774
                    sweet, thanks again
