How should you dial in the E30 for neutral handling on roadcourses? I'm thinking that since the rear cannot be adjusted besides raising and lowering for static camber, the front has to be tailord to what the rear is set at.
Here is some questions i've been pondering while at work...
So how should the front be set at compaired to the rear?
i've heard you want a little bit of toe out in the front. I've also heard that you want a little bit of toe in in the rear and 0 toe in the front.
max out the caster as far back as i can go? if my shock towers are crooked and the caster is uneaven, what adverse handling effects will i notice?
