E36 ABS in e30
  • SA E30
    • 1248
    E36 ABS in e30
    I've been thinking about this since I saw a thread on Bimmerforums speaking about ABS.
    I'm fairly sure it would be possible to implement a 3 channel e36 ABS into an e30 (that didn't come with ABS).
    The only glitch I can see are the ABS rings. For my application the fronts aren't a big issue as I already run e36 stuff up front. It's just the e30 M3 rear.
    Where is the ABS ring and sensor on the e30 M3? I can't say I've ever taken note as to where they are to be honest.
    Does anyone have the wiring or a how to make the ABS run standalone?
    I can also get hold of an e36 328i Group N ABS computer box, or at the worst get a chip from Europe.
    The only reason I'm considering running ABS is for the fact of saving tyres. I can threshold brake just fine for the most part. For the instant I don't I don't want to go out and kill a front tyre. They are rather expensive to just chuck away. Especially considering it's a rare size to.
  • FredK
    • 14763
    The ABS ring is built into the halfshaft, and the sensor resides in a hole bored into the trailing arm.
    I think as a part of the swap, it might be easiest to run Z3 M Roadster rear trailing arms, speed sensors, and Z3 M halfshafts. That way you balance the braking out and you also get identical tone wheels at all four corners.
    • SA E30
      • 1248
      Do the non ABS cars also have this hole?
      My trailing arms came from an 325i non abs and they have had a load of work done to them.
      So I would rather not change them, and there is also the fact that we never got the M z3 and the M Coupe parts are incredibly hard to come by here.
      Is that the hole that you are talking about there just below where the half shaft goes through the bearing?
      • Joe318is
        • Sep 2005
        • 6451
        EARLY 318's and 325e's [83/84] have a boss for the hole, but no hole. pretty easy to find trailing arms tho
        Originally posted by vlad
        • SA E30
          • 1248
          Seems like my arms don't have them, there isn't even a provision for them. The extra shielding that would go around the abs ring (on the trailing arm) appears to be missing.
          I will see if I can get some ABS half shafts and if they fit my arms then I can just fab a bracket to mount on the arm for the ABS sensor.
          • mattdk318i
            • Jun 2006
            • 3953
            I will be doing this in a few months, Im currently running a full 98 M3 harness. And the last step is the ABS pump. Im using 98 M3 front and TI rear. Fortunately i do have the correct ABS rings, I just have to get around to "plumbing" the pump
            • 2002maniac
              • 4260
              that hole in your arm is for the parking brake cable
