Tires for track wheels- (14s?)
If I had half a brain, that would be what I'd do. If I did not have so much money tied up in parts, I'd find an M20B25 in running condition, buy it, and drive. I have $100-150 in seals, gaskets, etc., plus $225 in swap hardparts (head, IM, ECU, etc.).
If I had it to do again I'd have just bought an "is" to begin with.
So many things that I have done wrong...Comment
Yeah- I head (885) with everything that bolts from there on up/forward, plus ECU, and cluster.
As for gaskets, I have all of the top-end stuff- IM gasket, head gasket, VC gasket, head bolts, WP and T-stat gaskets, TB kit, new WP, new T-stat, Cam seals, etc. Missing the exhaust mani gaskets, but pretty much everything else.Comment
On a somewhat related note, I just got a PM about a new set of the wheels (no tires) on my "preferred" list for $375 shipped.Comment
so sell the head and bolt-ons and pickup a motor, keep the gaskets/t-belt kit and freshen the motor you got, pull eta and swap in i motor.. no brainer ;)Yeah- I head (885) with everything that bolts from there on up/forward, plus ECU, and cluster.
I just emailed them.
I feel myself sinking into a pit of spending...
So new question- I have to run certain tires if I eventually go SpecE30, correct? And they are not really appropriate for the street, correct?
Crap.Comment
Yes, you need to run Toyo RA-1s (R-comps). I'd go with street tires for now and when you have some more experience get a set of RA-1s.Comment
You have to run 15x7 or 14x6 (well I think it's 14x6, but nobody runs those) wheels, at least 13.5lbs (the TRM C1s are a bit too light for SE30). SE30 tires are either RA1s or R888s, I can't remember what they are off the top of my head. Either way they're certainly streetable, especially if the car isn't a DD. Nando's running 235/50R15 R888s and I think he said they'd worn pretty well at 7-10k miles including track days and autox.
Edit: apparently they're RA1s :ppaint sucksComment
13# is the minimum. Tires are switched back to RA-1 for 2010 since Toyo started making them again after everyone bitched about R-888s. R-888s are still allowed through some grace period IIRC.You have to run 15x7 or 14x6 (well I think it's 14x6, but nobody runs those) wheels, at least 13.5lbs (the TRM C1s are a bit too light for SE30). SE30 tires are either RA1s or R888s, I can't remember what they are off the top of my head. Either way they're certainly streetable, especially if the car isn't a DD. Nando's running 235/50R15 R888s and I think he said they'd worn pretty well at 7-10k miles including track days and autox.
14x6.5 is also an allowed wheel size. allowed tire sizes are 205/55/14 or 205/50/15Comment
I've tracked and autocrossed falken azenis rt-215 in 195 on 14's as well as 205 on 15's. 195 got too hot and greasy quickly, and the 205s performed well on the track. auto-x they were fine either size and pretty fast
I've also ran 205 es100s on 15s and they put up well with tracking and auto-x, although not fast. I have a set of 205-60-14s now, but have not tracked them yet. They go alright at auto-x and street, albeit not as sticky. Skafrog was a big fan of them, and they're a good size on 14sComment
Still torn on whether to build the car for SpecE30, since I am a total rookie, but I would love to jump straight to 15s, right off of the bat.Comment
