Where to buy massive fender flares?
  • widebodye30
    • Jan 2006
    • 3407
    These pixs are prototypes....minor adjustments have been made for the final product! 4dr flares will be made first since were working on my car and then we will make 2dr.
    here are some prototype pixs... flares are 2" wider than stock fenders:)
    www.esmwheels.com
    www.dtmfiberwerkz.com
    Toll Free: 800.729.5450
    Local: 818.341.9903
    • theox69
      • May 2008
      • 1732
      ^those look pretty clean!
      you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
      • Blip Bavarian
        • 236
        Ary, those flares look good. how much will they cost once they are ready?
        My LS1 swap thread:
        http://www.r3vlimited.com/board/showthread.php?t=160030
        • widebodye30
          • Jan 2006
          • 3407
          They should be in the $295.00-$345.00 range:up:
          I will make a new thread when they are ready with price and installed pixs:)
          www.esmwheels.com
          Local: 818.341.9903
          • Pudmunkie
            • 210
            What material are you going to be offering?
            • widebodye30
              • Jan 2006
              • 3407
              FRP (Fiberglass Reinforced Plastic) or CFRP (Carbon Fiber Reinforced Plastic).
              Mold is finished for the 4dr. and we should have a few sets for sale soon:)
              Thanks,
              www.esmwheels.com
              Local: 818.341.9903
              • kronus
                • Apr 2008
                • 13032
                Thanks,
                Late model only?
                cars beep boop
                • widebodye30
                  • Jan 2006
                  • 3407
                  Originally posted by kronus
                  Late model only?
                  Any E30.
                  www.esmwheels.com
                  Local: 818.341.9903
                  • SA E30
                    • 1248
                    The only problem I have found with commercially available flares, with the exception of the Fibreartz and e30 M3 flares is that running the car super low on wide rubber still doesn't give you the clearance you need.
                    • MatRacer
                      • 562
                      I have IE fender flares, but not that sure if i'm going to install them.
                      What is your offset setup? If you add flare, you must be running low total offset. What about the rear wheel bearing and your steering offset.
                      Just trying to decide what I will do!
                      thanks!
                      your new flares look really nice!!
                      E30 now S52
                      2008 Suburban LTZ (Family and TT hauler)
                      325xiT (Sold)
                      • widebodye30
                        • Jan 2006
                        • 3407
                        thanks!
                        You can either run a low offset wheel to fill in the extra flare or you can use a normal offset (20-25) depending on the width of the wheel and run FAT tires:) Im sure either way we will have a wheels for you... ESM WHEELS!
                        Thanks,
                        www.esmwheels.com
                        Local: 818.341.9903
                        • MatRacer
                          • 562
                          This is clear to me...
                          My question is more about the impact of the final offset on the steering/suspension geometry
                          E30 now S52
                          325xiT (Sold)
                          • Dyno4mance
                            • 345
                            Thanks,
                            When is your web site going to be finished....I have been looking at the esm portion for weeks and it says check back shortly
                            Do you have any of the stagered esm wheels in stock?
                            Will the 9" fit on the front at all?
                            2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
                            • widebodye30
                              • Jan 2006
                              • 3407
                              Were working on it right now:) It should be up B4 new year! We do have all the wheels in stock and the 9" will fit on the front.
                              Please contact me at the shop for more info.
                              Thanks,
                              Ary
                              www.esmwheels.com
                              Local: 818.341.9903
                              • Axxe
                                • Aug 2004
                                • 3355
                                Your flares look like they won't be slammed with big tires friendly. I thought the whole point was to cut out some of the stock fender to give more room, those just make them wider....
                                Keep it slideways!!
