I'm wiring up a kill switch and in looking around this site as well as a few others, I have a few questions.
I bought a four pole switch that I'm planning on using. At this site, I read about using it to interrupt the thicker power cable from the battery as well as the smaller gauge wire that runs from the + terminal on the battery to the distribution block on the firewall.
The problem with that setup is that I've pulled my connections off of the + terminal with the car running before, and it keeps running (sometimes), so that's not going to work.
So here are my questions:
If I put the large poles of the switch between the power supply and the distribution block and the small poles as an interruptor for the hot side of the coil, will that take care of things or will I mess something up (i.e. blow the alternator)?
Also, I need the switch to kill everything when thrown. Is it OK to disconnect the smaller wire at the battery and have the remainder of its circuit pull power from the distribution block (after the switch)?
