Ride height to low hinder you handeling?
  • E30Pedia
    • 140
    Does having your ride height set too low really hinder your handeling? I heard going too low can make your cars handeling worse, but i dont see why. As long as the car dosnt bottom out you should be fine.
  • Massive Lee
    • Sep 2006
    • 6785
    A car that is heavily lowered needs to have its suspension geometry modified to account for the lowering: some type of roll center spacers for the control arms and steering arms, raising the subframe, etc.
    The lower the car, the stiffer the suspension should be. And not all tracks are friendly with extra stiff suspension. You don't want your car to bounce on bumps.
    BTW we are talking track stuff, right?
    massivebrakes.com
    • nrubenstein
      • 3148
      It's because of the crap front suspension geometry. Go too low and the car will actually want to roll more in a turn.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Skafrog
        • 1732
        Read this: http://www.e30m3project.com/e30m3per...t_transfer.htm
        Then, read the rest of the site. You will be 5x smarter than r3v after.
        NASA MidSouth TT Director / GTS2 #018
        Mods: Coastal PS Fluid, 10w40 Oil
        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
        • JMil86
          • Dec 2008
          • 558
          Just heat up your springs til they are red hot and then compress them with spring compressors, then cut off half of the coils. Dont bother with buying anything, or shocks or anything like that. This is the only way to do it.
          Nio är livets tal.
          • E30Pedia
            • 140
            Am talking about Track/AutoX/Canyons. My car is lowerd 2 inches all around. After hearing this, ive been thinking about rasing it. I am with H&R cup kits, which i dont think are stif enough. I do get considerable amount of bodyroll through turns.
            I see how it works now. Do the e36's come with this suspension geometry also?( sorry for not doing the search my self. Too damn lazy for my own good)
            Great info, thanks a lot.
            • E30Pedia
              • 140
              Naw braaa! No springs braaa.. h3lla flush braaa!
              • Massive Lee
                • Sep 2006
                • 6785
                Wow. There's a ghetto in Portland?
                massivebrakes.com
                • omar85
                  • 331
                  what is comes down to is the lower the cooler. period.
                  • 87e30
                    • Jul 2008
                    • 5676
                    So that begs the question.... what is too low? what is too stiff?
                    I just hate everyone.
                    No need for discretion.
                    • erik325i
                      • Jan 2005
                      • 3567
                      H&R Cup Kit springs are not for the track. They are far too soft. Get some real suspension (coilovers), and then play with the heights.
                      Erik
                      • SA E30
                        • 1248
                        That sounds like a rhetorical question.
                        It all depends on variables. How far are you prepared to modify your suspension/chassis, do your class rules allow for it, what is the car used for.
                        On stock geometry it is a function of both height and spring rate. Go only as low as it takes to get the control arms roughly level with the ground. Then you don't really want them to go past that so theoretically if you are going to have any travel you would still want a small angle / \ on your arms.
                        Making sense?
                        • Wh33lhop
                          • 11705
                          In terms of pure grip, the point at which your strut axis is perpendicular to the control arm is the crossover in the camber curve derivative--the point at which your dynamic camber is maxed out, and you will begin to lose negative camber on compression instead of gain it. Generally you'll want to set the ride height a good margin north of that point.
                          But "handling" is not quite as simple as camber curves, you also have to take into account the tie rod geometry, bump steer (and toe steer especially) is never fun. Strut travel, etc are also obviously equally as important.
                          paint sucks
                          • theox69
                            • May 2008
                            • 1732
                            Sway bars are your friend, in terms of body roll.
                            you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
                            • SA E30
                              • 1248
                              Yes and No. It is one way to control body roll but you can also do it with springs.
                              The downside to sway bars they don't allow the wheels to act independently.
                              The downside to using springs is that it can make the car over sprung and jumpy on a not so smooth track.
