Trailing arm bushings???
  • Blip Bavarian
    • 236
    Im looking for opinions/reviews of the acentric adjustable trailing arm bushings. Im looking at getting the AKG set, but they are pretty pricey.
    http://www.akgmotorsport.com/catalog/catalog.php
    What are you guys running?
    How is the adjustability? How much camber can you dial in with them?
    Thanks,
    -Matt
    My LS1 swap thread:
    http://www.r3vlimited.com/board/showthread.php?t=160030
  • Massive Lee
    • Sep 2006
    • 6785
    Hi Matt.
    I have AKG's eccentric bushings. They just are as good/bad as any other adjustable eccentric bushing. They are a waste of time and money. I strongly suggest the slotted adjusters. They cost slightly less, are as difficult to install, but at least they work much better and allow independent adjustment of camber vs toe.
    You might want to consider solid subframe mounts that raise the subframe, automatically removing some of the unwanted camber caused by lowering the car. As you'll run a V8, I guess you also want to keep the subframe from moving around. I know, it is another expense, and more work, but I guess it comes with the V8 ownership ;-)
    massivebrakes.com
      You can get about a degree of camber or toe with eccentric bushings. But they are a royal pain to align and you are fiddling with both bushings for each adjustment. Unless the tech gets real lucky, figure on 4-6 hours of labor to set the rear alignment. And they tend to work out of adjustment.
      A much better solution is the weld in adjustable RTAB's. They provide essentially independent adjustment of cam and toe and don't tend to drift out of adjustment.
      • Blip Bavarian
        • 236
        Originally posted by Massive Lee
        Hi Matt.
        Do you have any more info on the slotted adjusters you mentioned. I am not familiar with them? who makes them? link?
        I just bought and installed some powerflex subfarme mounts. I am gonna try em for now, and may go with your solid mounts down the road.
        My LS1 swap thread:
        • whiltebeitel
          • Apr 2007
          • 2098
          One the Spec E30 forums, there are complaints that thses will go out of alignment fairly quickly. They seem to prefer the weld-in kits.
          http://store.bimmerworld.com/shared/...t=products.asp the second from the top.
          '89 325i track sloot
          '01 530i daily
          -Enginerd
          • rThor432
            • Feb 2007
            • 3907
            As mentioned, weld-in adjustment kits are the way to go. Korman and IE carry them. Basically the "kit" consists of E39 eccentric adjustment bolts, washers, and nuts with slotted machined plates that will be welded in place where the trailing arm mounts.
            • funcrew
              • Jun 2007
              • 1223
              I'm NOT recommending the eccentric bushings, but Pelican Parts sells Febi eccentric bushings for $33 a side. I agree with the previous replies that weld-in is the way to go. The weld-in ones are illegal in SCCA STX class, unfortunately for me.
              "If the sky were to fall tomorrow, the tall would die first."
              -Dr. Paul Forrester
              Do I LOOK like I need a psychological evaluation???
              • blueapplesoda
                • Dec 2005
                • 1904
                i have a akg poly eccentric rtabs
                it is a royal pita to adjust
                it squeeks like hell
                they come out of adjustment over long periods of time
                car woke up in handling...rear end was just that much more in tune with the rest of the car.
                i have mixed feelings about them, and would not put them back in if i had to do it again.
                • Blip Bavarian
                  • 236
                  Thanks for all the advice guys. Looks like i will be going with a weld in setup.
                  For those of you who have a weld in setup, did you do then work yourself? and how difficult was it. Im not worried about the notching or welding, i just dont want to screw up the geometry. Thanks.
                  My LS1 swap thread:
                  • evil_twin
                    • Nov 2007
                    • 2965
                    subscribing to this thread :)
                    Paypal: vdang5@gmail.com
                    Delta Auto Care
                    2875-C Towerview Road
                    Herndon, VA
                    703.435.1375
                    My Feedback Thread: Evil_Twin
                    • Massive Lee
                      • Sep 2006
                      • 6785
                      When I purchased and fitted the eccentric bushings, I thought I would save time and money (even doing it myself). Fukk that. That was a waste of my time and dough. If I had known, I would have fitted sliders. Which I am going to do this Spring and dump the eccentric bushings. Not worth it.
                      massivebrakes.com
                      • Blip Bavarian
                        • 236
                        which bushings are you guys running with the weld on kits? Does any standard non eccentric bushing work? Thanks for the help.
                        My LS1 swap thread:
                        • rThor432
                          • Feb 2007
                          • 3907
                          I did the weld-in setup myself. It was very simple and straight-foward. Just blast/grind the paint off the spots that will be welded, create a good clean ground spot, bolt the plates in where you want them to stay, and do run a few beads. Takes less than an hour.
                          • Aptyp
                            • 6584
                            you're good.... takes me over an hour grinding slots.
                            Also, IE and many other aren't the same as Korman (McReynolds) kits. Korman allows for a more adjustment and uses custom made bolts, not e39 ones. But if I was to do this again, I'd go ahead and get IE kits, as you simply don't need that much adjustment.
                            • rThor432
                              • Feb 2007
                              • 3907
                              My 90 degree dremel opens the slots up quickly. The inboard slots by the diff are the hardest. Those two alone took as long as the rest of them combined.
                              I thought about using Korman's kit, but I agree with your thought that it is an unnecessary amount of adjustment. The E39 bolts will easily set your toe right and can cancel out excessive negative camber no problem, even on a slammed car if they are set up right.
