Conversion to manual windows
  • iamsam
    • Jun 2008
    • 173
    I did some quick searching, didn't find much, so I'll go ahead and start this thread.
    Two questions:
    1. how much weight (approximately) will be saved in a conversion to manual windows in my late model coupe?
    2. How to do such a conversion? (will early model coupe doors bolt right on? are all E30 coupe doors the same?)
    Thanks dudes!
  • Jean
    • 18228
    You can just get the early manual window regulators and matching glass instead of swapping complete doors.
    • iamsam
      • Jun 2008
      • 173
      why would you need matching glass?
      and can you do complete doors? because i need a new door anyway, its a bit crunched.
      btw i did find this: http://www.r3vlimited.com/board/show...manual+windows
      and this: http://www.r3vlimited.com/board/show...manual+windows
      • Jean
        • 18228
        You would need matching glass because the mounting points are different between early/late model window regulators.. what do you think.
        Very early doors vs late model actually have different wiring connectors/plugs that connect to the chassis.
        • iamsam
          • Jun 2008
          • 173
          that makes sense.
          But other than the plugs, are early and late doors the same?
          • hendrixvodu
            • Jan 2007
            • 2514
            i can tell you that the manual doors feel wayyy lighter
            -His-
            87 e30 325i
            87 e24 m6
            05 e83 x3
            94 e32 740i 5spd
            -Hers-
            89 e30 325i
            18 f48 x1
            • erik325i
              • Jan 2005
              • 3567
              But that shouldn't really be an issue though. Once you swap to manual windows, the only wiring that goes to the doors is for the switch to adjust the side mirrors. Since this is on a track car (I'm assuming this much since the question is in the track subforum) I'm sure he won't mind if the power mirrors don't work.
              To answer your original question, I don't see why it wouldn't work. Any of the coupe doors should work, so just swap out the whole door.
              • Jean
                • 18228
                As far as I know they are the same (other than convertible doors), others will confirm.
                • iamsam
                  • Jun 2008
                  • 173
                  and iirc, the early manual window doors also didn't have power locks. And I can easily wire up the mirror adjuster, as this is my DD and track car. I am trying to make it as much of a track car as I can while still a DD.
                  • surebimmer
                    • Jan 2004
                    • 978
                    I took manual window regulators out of a car at the junk yard and swapped them into my M3 didn't have to swap glass. Doesn't really save that much weight. All you save is the weight of the electric motor.
                    • iamsam
                      • Jun 2008
                      • 173
                      ...probably not worth it then.
                      • paynemw
                        • Dec 2015
                        • 439
                        bumping this thread. Anyone have PNs for the window regulators we need? I want to purchase some while in Germany and ship them home. I have issues with my door harness at the plug, this the major reason to swap out the electric motors.
