Recommended alignment settings?
    I did a search but did not find the actual recommended settings. I have what will be a track dedicated E30 with IE sways and a Ground Control suspension. What are the recommended alignment settings or what do you use? Trying to get ready for an upcomming autocross.
    Thanks,
    Rob.
    I'd go with zero toe in the front, and if you have adjustable rear bushings, minimal rear toe in. As for camber, play around with air pressures and camber degrees until you get fairly even tire wear.
    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
      Depends on how serious you are.....
      I would not mess around with 'settings', unless you know what you and your car can do at the limits.... I would even keep tire pressures at the same pressure....
        Is this a track car or an autox car? For a track car I would run 1/16 in front and rear. For an autox car I would run 1/16 out and 1/16 in on the rear.
