so, what's the bottom point? i shouldn't run the coilovers on any type of not-shortened shock?
i don't mind welding the shit on there, but i would like some nice shocks
long story short:
the rrs you described need to be removed to adjust...altho I know of a few folks that do it on car...but bottom bolt needs to be undone....the top adj rrs adjust from inside the trunk!...BUT you prolly will never adjust them.....most folks on the street dont.
If you buy OTS rr shocks.....Im not sure 700 lbs wont blow them out in a yr or so....
so buy frt OTS.......and talk to GC about rrs.......
ask GCs opinion about OTS Konis and your rates....but 450 frt is not hat hi...
I did talk to gc, and as much as i'd like to buy their stuff, i can't afford 1500 right now. They said that if i can find Koni sport that i'll be good to go and just weld the sleeves to the strut housings.
I'd be very happy if they hold up a year. I'm not expecting them to last forever, i know i'll get what i pay for, so a year i'd be happy like a pig in shit.
Right now i gotta M50 that i had laying around going in it, next sumer i hope to have an s52 completely rebuilt and ready to drop in the car, which would that i could get a full g/c setup.
thmotorsports.com 147/piece on the front 94/piece on the back.
i'm gonna run g/c coils with 450 front and 700 rear springs
I'm pretty sure that is the GC set up my son ended up with on his '89 I. Koni sport shocks SA front/rear. pretty decent for DD , drivers school,spirited drives. weld the spring perch plate, not the sleeve!,to the strut tube. Cost was a factor in our shock selection. ended up at Shox.com since GC didn't have stock. GL
Might want to upgrade your rear shock mounts GC, AKG ect.
Reason: Add info
