Lollipop
  • F34R
    sLaughter
    • 12376
    Lollipop
    I have seen the treehouse lollipop bushings, but I just found AKG makes them too. Any one else using them? I would love some feed back!
    http://www.akgmotorsport.com/catalog...Control%20Arms
    I also want to put in polly subframe bushings. What brand and kind should I get?
    This is for my DD/scca solo-x car. I my e30 loves 'em stiff!
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
  • Danny
    • 14216
    Treehouse racing.
    • HarryPotter
      • Jan 2010
      • 3642
      I have the tree house eyeball arms, woulda loved to have seen these and saved 40 bucks.
      They kick serious ass btw. (the treehouse ones)
      On second thought those look kinda sketch. I'd go with the treehouse ones. There good people. My order seemed to have slipped through their computer or some shit but they cleared it up after I called em up.
      John F. Kennedy
      • F34R
        sLaughter
        • 12376
        Thanks, I was not sure on how the AKG ones hold up. For extra 20 I'll get the treehouse ones.
        Anyone know a good brand for the subframe mounts? I think the red AKG ones for 100 is a great deal.
        Current cars:
        ~ '87 535
        ~ '06 X5 4.8is
        • dnova89
          • Aug 2009
          • 851
          I have the treehouse lollipops and AKG bushings everywhere else. AKG bushings are great, but I have no experience with their lollipops. Can't go wrong with my combo!
          -Darius (aka DiscoDoughnuts on other forums)
          dude man bro...
          • SA E30
            • 1248
            Those look like they would be good for the e36 swap guys?
            • HarryPotter
              • Jan 2010
              • 3642
              the akg bushings are a very nice product.
              John F. Kennedy
              • MoparJ
                • May 2007
                • 258
                Heim joints are a high quality design and work well for race applications, but as a replacement for bushings they would be a fairly harsh ride for the street.
                Jason
                • F34R
                  sLaughter
                  • 12376
                  Over solid polly bushings? If so link me, I am not in need of comfort.
                  P.S. Suspensions suck SO MUCH MONEY on the builds.
                  Current cars:
                  ~ '87 535
                  ~ '06 X5 4.8is
                  • HarryPotter
                    • Jan 2010
                    • 3642
                    I'd still go with treehouses solid mount, it is of one piece design.
                    John F. Kennedy
                    • MoparJ
                      • May 2007
                      • 258
                      Yes, although not by a whole lot. A heim joint is all metal; a type of bearing for the most part, so it will still be more harsh than a bushing, even a hard duro poly or thin thermoplastic bushing.
                      Jason
                      • HarryPotter
                        • Jan 2010
                        • 3642
                        My ride quality isn't that bad.
                        John F. Kennedy
                        • Charley
                          • 396
                          The ride quality should be the same at least what you will feel behind
                          the wheel will be almost the same.
                          The THR unit has the advantage of being a solid mount+no maintenance
                          whatsoever. They are also super easy to install.
                          The AKG unit has the advantage of being adjustable but also the
                          disavantage/possiblity of becoming loose and heim joints need to
                          be cleaned/checked for wear often(will wear faster than THR's).
                          I love most parts AKG sell but this part really deserves this warning:
                          Recommended for race use only
                          Also getting replacement parts for the THR's are probably cheaper
                          (if not free) than the AKG setup. Plastic sleeves are cheaper than
                          2 new heim joints and you would probably need an alignment everytime
                          you play with the AKG cabs.
                          I think the THR's are better for 99% of us.
                          Charley
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            does the THR or AKG cabs give you more caster?...I just bought and installed offset bushing and got 9.5% of caster :):):)
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • HarryPotter
                              • Jan 2010
                              • 3642
                              yes at least the thr's do seems the akgs have adjustments.
                              John F. Kennedy
