Hey guys... not looking for an intellectual property lawsuit, but was hoping for some guidance...
I built my e30 to spec e30 rules, minus the rollcage... Going to attempt to adjust the alignment over the weekend using an alignment kit (with the strings and the whole 9).
Im going to be driving the car to DEs for a few months.. with that in mind Im hoping to max out the neg camber in the front (-3 to -3.5 degrees) but to keep the toe at 0.
The car has Bilstein sports with H&R race springs and GC Camber plates.. AKG 75d bushings all around.. offset front FCABS, and non eccentric AKG rear trailing arm bushings.. Also, not running any spring pads at the moment..
-Should I max out the caster in the front?
- Since I dont have the eccentric RTABS, Im under the impression that I can't adjust rear camber and toe.. What kind of camber and toe setting can / should I expect in the rear? Im concerned with this because it looks as if there is alot more toe-in on the drivers side rear and Im wondering if my trailing arm and or subframe is bent..
Thanks in advance for any advice / info you're willing to share..
