Well here is the story, I didn't just buy coilovers for the higher spring rates or lowered drop, I wanted to take advantage of the fact that I can attempt to make the car perfectly balanced. Before I go on, the car is a daily driver and weekend HPDE car. My goal is to have it as balanced, while making it lighter at the same time. My plan is to remove A/C and components (30lbs?), remove rear trunk tar (40lbs?), and maybe remove the back seats (30lbs?). Spare and jack already removed (40lbs?). Its an m20, and the registration states it weights 1380kg (Which seems like a lot to me...)
That said, I want to get the car on scales to improve the overall balance of the car. I am a noob when it comes to corner weighing so any editorials will be great, and for anyone else as well who wishes to do this in the future.
As I understand, getting the front/rear and left/right weights is for a pure track car where ballast is actually moved around to achieve 50/50. And for a non-track car the cross weights is what is important. Double check if this is correct, I may have misunderstood.
So the key points Im looking for are:
-Is it worth the time and money? I have heard mixed reviews on this...
-Will taking out the trunk tar/spare really make the weights off that it will be harder to achieve a perfect balance?
-Is it recommended to leave as much weight in the rear as possible to keep it balanced?
-Should I first balance the car as-is to see what my starting point is, to see if it is even worth it?
Thanks for the input. Any help will be great.
If anyone else has questions, please join in.
