2 Question to those who've experimented with and/or are running without a rear anti-roll bar for race, TT or HPDE.
I'm interested in hearing what spring rates people are running with NO rear bar, or stock rear bar. Especially if you've tried various bar settings (stock, non-stock, none) with your current spring rates.
I'm looking for data/facts - In the end, I'm hoping to find what makes the car faster or easier to drive at the limit, based on a decent sample size.
Background on this question - This is for a Chump car build, so I'm very limited on what I can get away with for springs and bars. A lot of what I've read indicate no rear bar can work very well, I just want to find out where that point is so I can target to get springs at/near those rates. Or I'll find out if I need to do some mods to my current bar, or find a cab bar, etc.
- At what rear spring rate does the rear become stiff enough that the rear bar can/should be removed? example - 400 lb/in = use adjustable rear bar. 650 lb/in, remove rear bar.
- How is your track car set-up now? List out the FR/RR spring rates and what bars you've tried and some notes on the setup. i.e., what has been your experience with handling of the car with various rear anti-roll bar setups?
