Thought I would post a link to it here .
Coil spring rate and sway bar stiffness discussion on another forum
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Tags: None
I agree completely with their tuning ideas,run as stiff a spring as you can control with the dampers and tune with small bars.Thats for heavy'ish production cars.
I played with several different set-ups on my composite bodied AE86 corolla and prefered the no bars stiff spring,it was low enough and light enough for it too work.You can read a very in depth writeup about no bars on the MR2OC forum written by the DP national champ Steve Hoescele(I know its misspelled)
The open wheel car I built is designed around no bars as well,the CG is less than 18" off the ground and weighs 900lbs.
