Strut brace and X brace question?
  • Massimo
    • Jan 2008
    • 3207
    Hi Guys
    Thought I would post this on in the track section since you guys put your cars through alot more then the rest of us. Anyways my car has bone stock suspnsion that has probably not been refeshed in 10 years. I am now upgradings and refreshing her with Billi sports, H&R race, poly bushes (offset subframe bushes) UUC swaybar 22/19, GC tourning camber plates, I also run the car in Dunlop Star Specs.
    So I am deciding on weather I need Strut braces and a cross brace? What are your opinions on these dose the E30 need them? I currently don't track the car but will be once I have the suspension refeshed, it is also my DD.
    cheers guys
  • ak-
    • 12422
    With all that done, I don't think you're going to feel much of a different with a strut brace.
    I have no experience with x-braces, though they appear to be more beneficial towards verts everyone says.
    1991 325iS turbo
    • Massimo
      • Jan 2008
      • 3207
      What about bending the chassis or is that just an urban legend. I though the strut braces helped to stop you from bending the struts under high loads like racing?
      • Turd
        • 185
        Track the car after you refresh your suspension and learn to drive it. No need to go buying a whole bunch of parts off the bat.
        • Jafxod
          • May 2011
          • 1301
          Yup, thats just money spent for nothing, its not like your racing or will even be able to push the car to the point where the difference would be appreciated. Just go have fun driving.
          • Massimo
            • Jan 2008
            • 3207
            Cool I see where you guys are comming and I understand what you are all saying, and I completely agree with you but it dose not answer my question as to the benifits of the strut and x brace and if the E30 really needs one. The only real reason as to why I would get one is to keep the car from twisting but I have been told that the E30 dose not really need a x and strut brace.
            • bmwguy325is
              • May 2011
              • 1263
              I bought the mason front and rear braces and the sub frame brace. The biggest difference I noticed is that the car turns in better and the steering is more responsive.
              I do agree on learning to drive the car. But I also think they make a difference. The front one more so than the rear. The best upgrade you can make is the rebuild the rear subframe.
              sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
              The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
              • !kid
                • 1362
                personaly I have my doubts on how stiff the chassis is on our 24 ish old cars. generaly I also feel strut tower bars and that sort of thing are for "fine tuning" your suspension.
                check out this vid, it will give you a good idea on strut tower bars and chassis reinforcments
                :borg:
                • TurboJake
                  • 3780
                  FWIW, my car creaks less during every day turning after i installed my hartge front strut brace.
                  Have I noticed a handling difference? Not really no.... I still have OEM suspension parts....
                  Leave Me Transaction Feedback
                    I've not seen any difference in lap times in my Spec E30 with or without the strut brace, nor have I heard of any other racers finding a difference. The brace probably does make a small amount of difference, but other factors have a bigger affect. I think it is a good thing to have as it will lessen flexing of the shock towers, but don't expect noticably better handling from a brace.
                    • Massimo
                      • Jan 2008
                      • 3207
                      Sweet thanks guys for the help. I think ill will get everything else on then when I have some more monies ill get the strut braces just because.
                      • TimR
                        • Mar 2008
                        • 549
                        The strut brace made a noticable difference on my Vert. but not on my coupe. I'd agree wait til you got track time, its like headers good ones are $1000 and if the guy beating you EVERY weekend has them maybe you need them. I allways try to look at $$$ per HP and or seconds on lap times.
