Autocrossing an '84 325e
  • Varinn
    • 780
    That's right, an eta. Am I crazy? I want to learn how to properly drive my car before dreaming of stepping up to something more powerful.
    Currently I'm rocking very few mods,
    H&R/billy sports
    15x7 Racing Dynamics with 205/50/15 Falken Azeni rt-215
    Thats it. Would I benefit greatly from a chip?
    The car is for the most part mechanically sound, previous owner was a friend of mine that runs his own BMW service shop. New top end installed 25k (km) ago, new oem pads/rotors, tierods, control arms, trailing arm bushings, engine/tranny/diff mounts, shift bushings, redline fluids in gearboxes, front hubs, ATE superblue brake fluid
    What else do I need to look at? I want to be free of worries with the car so I can spend my time focusing on not driving stupid
    1990 332i, 4 door
    2008 KTM 990 Superduke
    2018 Golf R, 6spd manual (Pending delivery)
    2017 Mazda CX-5 GT
    2007 Z4M Coupe - Sold to very nice people
  • Danny
    • 14216
    Go out and drive then if you want to get better. Seat time > mods.
    • Varinn
      • 780
      I'm less concerned with mods, and more concerned about common failure points I might have missed checking. I'd hate to say, lose my blinker fluid in a hard corner because I forgot to check something ;)
      1990 332i, 4 door
      2017 Mazda CX-5 GT
      • Holland
        • Nov 2008
        • 7176
        Timing belt! :D
        Originally posted by DEV0 E30
        • paresmi
          • May 2011
          • 31
          After all your standard maintenance is done I would say yes to a chip.
          I know I'm new to the game but I know my eta's performance greatly improved from the Conforti chip. Cheapest horsepower per dollar you could do.
          • devon.818
            • Feb 2011
            • 2937
            BEST HP/dollar you can do.
            your eta will autoX great. its a torque monster with a chip. if you really get into, think about swapping the diff for a 3.73lsd.
            • Jean
              • 18228
              Don't worry about it being 325e, as others have said seat time is everything. Just make sure your car is in sound mechanical condition (tires, brakes, brake lines, clutch, driveshaft, shifter, bushings, hoses, belts, fluids, radiator). RT615s are fine, when I still had an m10 in my car a few years back with enough seat time I ended up placing faster than a local guy with s52 swap... Go have fun!
              • Holland
                • Nov 2008
                • 7176
                M10 ftw!
                • TimR
                  • Mar 2008
                  • 549
                  Seat time # 1, If you have class limits on mods Diff the best for the $$$ on an E, ask around you might find the 325 - 346 LSD the best choice for second gear 50 mph tops. The 205-50-15 isn't a tall tire, chip 25 HP done for 20+ years, good brake shoes, Buy used parts in the spring, thats where everyone is upgrading and prices are right,
                  • Gary Horneck
                    • May 2011
                    • 435
                    "I want to learn how to properly drive my car before dreaming of stepping up to something more powerful." My thoughts exactly!
                    I just spent the last two months bringing back to life a '87 325e, just for Autocross. The car had been neglected and sat under a tree for several years. The night before the last event, my new TRE fuel pump died and killed that fun day. Today was the first day out with it. Running 195/60/14 Direza's with Dinan bars, Bilsteins, offset CAB's and PowerFlex TAB's. A knockoff eBay chip was all that was in the budget, but it pulls hard. The axle tag is unreadable, but I think it's a 2.94 open. I was able run the course in 2nd only, with good dig coming out of slow speed stuff. I guess it does ok. I took 2nd place in Novice. Video - http://www.youtube.com/watch?v=BYuuj64RWTw
                    2011 335i/1995 Mercedes C220 (rallyx)
                    • jstam
                      • Jul 2010
                      • 48
                      subframe bushings? You mentioned a lot of replaced bushings, but not those. It's just on my mind b/c I am getting ready to do mine. Also, is the driveshaft guibo OK - i.e. no vibrations or cracks?
                      Sounds like your eta is well-taken care of. But be sure to check that fuel lines are not cracked/old. It's a cheap/easy replacement. Also, are both your fuel pumps healthy?
                      Eta with a chip and a LSD (>=3.23) will be a great car. The chip is definitely the best bang for the buck. My car is set up very similarly to yours and i'm sure yours will be very competitive as long as there aren't long straights where high HP cars can blow by you (probably not an issues in auto-x). But the car as you have it set up will be great and have generally neutral handling characteristics. Have fun!
                      1985 325e, 74k miles (S52 w/ OBD1, Bistein Sports, H&R Sports, IE sways, 3.23 LSD, TD 15x7/Star Specs, Euro bumper conversion)
                      1998 M3 (4dr, 5sp, TCKline) (sold)
                      2002 325i (sold)
                      2009 X5 3.0si
                      • Varinn
                        • 780
                        Sweet, appreciate the input! I've checked over my maintenance records and done a few more things. Effectively, every bushing/steering and suspension component has been replaced between january 2010 and now. I've got a sticky right front caliper though, so tomorrow I'm going to be doing a swap and a full bleed with fresh superblue. Also,an oil change and coolant flush so I can replace a slightly ugly upper rad hose. Fan/clutch are working well and I've cleaned the rad fins to make sure cooling won't be hindered. Battery hold-down is solid and no fuel leaks found, pumps seem to be working well. I may install a fresh fuel filter tomorrow as it only takes a minute
                        1990 332i, 4 door
                        2017 Mazda CX-5 GT
                        • TimR
                          • Mar 2008
                          • 549
                          A 325 I TB is nice on an ETA, way faster pick up, 5mm larger, got it on mine.
                          • jstam
                            • Jul 2010
                            • 48
                            So just an "i" throttle body, nothing else? No changes in ECU, etc. and all runs right?
                            To the OP - your car will be solid. I've subjected mine to more abuse in a few track days in 100+ weather than an auto-x and it's held up great. Problems I've had (upper rad hose came unmoored from block, fan shaved it down to scary-thin) are things you'll have taken care of.
                            2002 325i (sold)
                            2009 X5 3.0si
                            • 325ix
                              • Aug 2009
                              • 7783
                              Definitely change your motor mounts. Otherwise a nice 3.91 diff, a chip and seat time.
