88 E30 AutoX Springs
  • delta159
    • May 2011
    • 7
    Anyone got part number suggestions for Race Springs for my E30. The Eibach's sports have major suckage.
  • JeremyE30autox
    • Dec 2010
    • 404
    What class are you running?
    If you must stick with springs H&R race springs are the way to go.
    If you can do a coilover conversion that is probably better for you, then you can choose spring rates
    Dare 2 Dream Motorsports
    • delta159
      • May 2011
      • 7
      right now just running ST, but considering DSP. Thanks for you input, it will help.
      Wheels
      D-Force 15 x 7
      225/45 hankook RS3
      Exhaust
      Ebay Special
      Eibach springs and Sway Bars.
      Just got the car a couple of months ago
      • Mike The Bavarian
        • 488
        try tunermotorsports jstock springs with their bilsteins.(they're revalved for the spring rates)
        • BMWLOCO
          • 129
          HR and Koni Adjustables... and don't forget the Sparco front strut brace!
          - Y2K M Coupe (DD, Track Rat)
          - '08 Land Cruiser (Family Hauler/Tow)
          - '90 E30 4/5sp. (DD/ Son)
          - '87 AW11 Mr2 (AutoX-Rally-Track)
          - '06 Royal Enfield Bullet 350 w/sidecar (weekend cruiser)
          Future
          - E92 M3
          - 88-91 M3 (maybe.. if I can find one, regret selling in 05)
          - Richie
          • Boris3
            • Apr 2007
            • 441
            Coilovers tends to be the better approach: ground control for low budget, AST and others for higher. H&R race will be stiffer than the Eibachs but most folks will say not stiff enough to be competitive.
            The answer to your question really depends on class and budget, how streetable you want the car, how competitive you already are and want to be (local, regional, national). If you are in it for fun or starting out and have limited budget, bump up the springs with a set of used H&Rs and get as much seat time as you can.
            If the proposed SCCA class reorganization goes through ST is out for e30s and you will be in STX, DSP, or SM (depending on your prep). In either case a 15x7 wheel is small. The 15 kooks are also happier on a 7.5, 8, or larger to take advantage of the width. Also in STX and DSP you will be competing against folks with LSDs and r-comps.
            Welcome to the slippery slope.
            1990 325: track/racecar
            2003 330xi; project car
            2004 330i zhp: civilized car
            • Cabriolet
              • 9620
              H&R race, koni yellow adjustables. and get some good sway bars. and dump the ebay chip, get a good quality one.
              only reason to go coilover is if you are on a high speed track. i bet you will find a better weigh sift with springs and shocks. there tends to be alot faster turns and the coils never do as well as a good spring shocks and sways.
              Much wow
              I hate 4 doors
              • Gary Horneck
                • May 2011
                • 435
                I am not liking the sports either. I too am running my car in ST. We are so going to get clobbered when and if they kick us out of ST.
                2011 335i/1995 Mercedes C220 (rallyx)
                • Jean
                  • 18228
                  Where are you getting this from...
                  • Danny
                    • 14216
                    Misinformation FTW!
                    • Cabriolet
                      • 9620
                      autox days.
                      having not enough play in the tail causes a lot more issues as you hit those high spring rates. (usually not as smooth a track day)
                      Much wow
                      I hate 4 doors
                      • Jean
                        • 18228
                        Disconnect rear sway and try again. Coil overs just fine in Autocross especially with sticky tires.
                        What is or was your specific setup?
                        • Cabriolet
                          • 9620
                          my current set up needs to be crap bc its a DD and a vert. i'm on dinan springs and koni adjustables. its way way too soft to be competitive. but i have raced my friends hardtop with HR+billy sports. and sways: 24mm/22mm. it was much better, still a tad too soft but he also dailies it. i have also ridden in a few e30s with coils out there. and with the changing crappy terrain they were not worth the point gain. with "BMWCCA-GGC Autocross" HR race are lower points than coils. and when you slap those on they pit you against tuned e46 m3s.
                          i do agree with jean, coils are the best. but are they worth the point gain on your car and are you willing to be beat to death by every bump if this is your DD?
                          Much wow
                          I hate 4 doors
                          • Sagaris
                            • Sep 2009
                            • 2243
                            If you value handling over looks then coilovers are certainly the way to go. Being able to change the ride height independently allows you to corner-weight the car as well as changing the height to bring the roll center closer to the center of gravity.
                            • Jb325is
                              • 2137
                              A swapped e30 with coilovers and stickies is good competition for e46 m3's, even with coilovers and R-comps... I will admit that an e30 with H&R's is a better DD, but when it comes to auto-x there is just no comparison.
                              - '88 m54 coupe
                              <3
