Greetings!
I wanted to get some insight and help from the E30 community regarding electric fans. I am going to be replacing my mechanical clutch fan with a 16” Puller SPAL from bimmerworld (Model 30100400).
I am retaining the stock A/C system including the auxiliary fan that connects to the side of the radiator. The car is a 1990 model with aluminum Mishimoto radiator and is a multipurpose California car (autox, track day car, daily driver). The car is run at Willowsprings and Buttonwillow if that helps any.
The main reason for this post is regarding how to hook up the electric fan. I have searched the main E30 forums (r3v and e30tech) as well as spece30 forums and the majority of people either wire up their electric fan directly to a switch in the cabin or use the thermoswitch/bung on the passenger side of the radiator. As I am planning on keeping the air conditioning I would like to keep the auxillary fan operational. I plan on using an “adjustable temperature control switch” similar to the one below available from JEGS. It uses a probe type sensor that is inserted between the radiator coolant tubes and allows for fan activation between 160-240 *F
I am also planning on purchasing the SPAL installation harness kit with relay from bimmerworld and modifying the OEM shroud to accommodate the fan.
Will this combination work successfully? Any positive input would be appreciated.
Parts to be used:
16" SPAL puller - Bimmerworld
Adjustable temp control switch - JEGS
SPAL rubber fan surround gasket - Bimmerworld
Billet water pump shaft nut - Bimmerworld
SPAL Installation harness w/ Relay – Bimmerworld
Thanks
Parts to be used:
Thanks
