Tire Softener?
  • Lof8
    • Oct 2006
    • 2827
    Tire Softener?
    I bought an old set of R-comp tires that need a little help. Any recommendations on tire softener stuff?
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • bmw325csi
    • May 2007
    • 4045
    I used leather conditioner with good results
    harry/harout
    • L8 apexr
      • Dec 2010
      • 226
      The best thing you can do for them is to go and scrub them,the rubber under the surface will be a litle softer.If your using them for track days they will be fine,just take the first couple laps gentle'ish to build the heat and away ya go.
      The trouble/cost of tire softening isn't worth it imo(messy and stinky),been there tried it with less than stellar results.Also the rubber will harden worse than it was to start with after you use the tire.
      • Wh33lhop
        • 11705
        Brakestand. Rotate tires and repeat.
        paint sucks
        • TrackjunkiE30
          • Sep 2009
          • 151
          You can use a few different options for softeners, store bought or home made. I used a combination of WD40 & mineral spirits. It works great for a session, possibly 2, but you have to prep them for a few days.
          John
          2013 NASA-SE TTE Champion
          Tracks driven: AMP, Barber, CMP, CMS (Lowe's), Daytona, NCCAR, Road Atlanta, Rockingham, RRR, Sebring, Texas World Speedway, VIR (Full, Grand, South, North, & Patriot), Watkins Glen.
          • Charlie
            kid tested, administrator approved
            • 6686
            Formula Vee works halfway decent on old dried out R comps, it'll get you a couple of sessions. You can usually order it through Pegasus racing and such.
            -Charlie
            Swing wild, brake later, don't apologize.
            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
            FYYFF
              Track Claw is also good (http://trackclaw.com/trackenter.htm). Since none of the treatments penetrate deeply, the effects don't last long. Maybe a session or two.
              • cabriodster87
                • Jan 2011
                • 1042
                Taken from Grassroots Motorsports: Tire softening or soaking is without a doubt the most harmful thing to race tracks. It leaves a petroleum based product on the surface, later the rain removes the asphalt ( black tar like stuff) right off the surface. This in turn, leaves the rock in the pavement up at the top of the surface, now you're trying to grip little spots instead of a smooth surface. Many track surfaces have been ruined unknowingly, to most, trying to save a buck. Probably not good for your heath anyway!!
                Okay, put no more than a quarter cup of brake fluid inside the tire when you mount it on the wheel. (works real good on bias ply)
                Reich und Roll!
                • ed94r
                  • Mar 2004
                  • 382
                  I'll share one secret:
                  Simple Green after each session / event. Clean the tires off, spray 'em good, then bag. They'll be sticky for the next event. I won an SCCA solo divisional on 4 year old 710's this way. I learned this from some dirt track cart guys; how they treat their tires means all the difference in how they finish. It's a black art.
                  Ed
                  1988 E30/S50...now with S52; Track
                  1994 Miata R; ES Solo2
                  1998 Lexus LX470; Wife (Slee'd anyway)
                  2002 BMW 530i; A+ Commuter
                  2002 BMW 325iT; Sport/Premium 5-speed
                  2011 21' EconoTrailer
                  • priapism
                    • 1182
                    Formula V tire treatment.
                    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
                    • Smelser
                      • Feb 2011
                      • 633
                      Same, From the DIRT world, You can buy a "BUFFING wheel" like they use to Patch the inside of the tire with, but its meant for a 7.5" angle grinder, just grind away the top 1/32" of tread and BANGO, virgin soft rubber underneath!!
                      sigpic1984 318i Total conversion to a DIRT race car.
                      Check out our build on facebook @ www.facebook.com/brewstermotorsports
