Have Dunlop Star Specs mounted on 15x7 wheels on our E30 project for chump car. Looking for advice on what people are using for cold pressures on these tires for track use. Thanks
Tire Pressures for Star Specs
I target 28psi hot so depending on the temp that day and driving style cold pressure might be around 24psi. I don't have a lot of experience but for HPDE's that is what has worked for me. A long race may be completely different. As the day goes on I usually have to let some more air out as the track temp increases.
I believe we were shooting for 38 hot at the Chump Car race at Nelson's ledges. Cold pressures would have been around 30+/- 2 psi. You'll have to adjust a bit depending on the track. For Road America, we will likely start at ~31-32 left side and 33-34 right side.
Where is your first race going to be?Ben
Thelma-Louise, the '88is Chump Car - back to M20 power!
2014 ChumpCar Season Schedule!
April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
May23-25 Watkins Glen, NY: 4th, 5th, 4th
October 4 PittRace Sprints: 2nd in C-class
October 18-19 NCM, Bowling Green KY: 2nd, 1st!
Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
Find us on FB! Schaut Speed Motorsports
Originally posted by NigelStu View PostI believe we were shooting for 38 hot at the Chump Car race at Nelson's ledges. Cold pressures would have been around 30+/- 2 psi. You'll have to adjust a bit depending on the track. For Road America, we will likely start at ~31-32 left side and 33-34 right side.
We settled on 35.5 hot for the Azenis on our Lemon, and the Star Specs have the same compound so I'd go in that area. Start at 28-29 or so in the cold morning and they'd get up to 35 or so. 26 seems way low! These aren't race tires, they're street tires.sigpic
-Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
Testing is really the best way to figure out what works best.
Easiest way to do it is to start high pressures; drop 2 psi each session. Mark the edges of the tires (tire chalk, silver marker, white shoe polish, etc) so you can see how much sidewall roll-over you are getting. Tire pressures and temps across the tires after each session. Look for even temps and minimal roll-over, but in the end go with the pressure that yields the best lap times and best 'feel' for your driving style.
And when I say 'hot' pressure, I mean immediately after coming off the track from a spirited lap, in pit lane - not back in the paddock area. (I will generally see a 1-2 psi drop between a crew guy taking pressures in pit lane vs. me taking them in my paddock spot).
For reference, on Toyo RA-1s (Spec Miata), I'm targeting 38-39 psi hot (usually 1 psi higher in rear for car balance). In our E90 M3 on Michelin Pilot Sports, we target 39-40. Figured the same ball park would be a good place to start and seemed to work pretty well with good temp numbers and wear characteristics.Ben
I'm pretty sure NigelStu has my tiny bit of experience on the track beat, but here is my little anecdote.
First, I found out that there is "Cold", "Hot", and "Track Hot". By this I mean that I drove 60 freeway miles, and a mile from the off ramp was the track, where I checked my tire pressure. I checked it a third time after my first (and slow) run. Here are the pressures I recorded with a decent gauge.
Cold = 32 psi (36F morning)
Hot = 38 psi (off freeway)
Track Hot = 41-42 psi (after first run)
And let me tell you, 42 made my back end rather sloppy ;)
I dropped it down to 38 rear and 37 front and it handled rather nicely in my inexperienced hands. A guy at the track that races E30's suggested 38-39 for star specs, but I believe he admitted to not having run that tire in a long time.
Edit: I am running 205/50/15 on 15x7 wheels.-------------------------------------------------
1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
Originally posted by E30Gus View Post^ and you're on 15x7's?
Kosei K1 with 10 mm spacer or TRM C1sBen
May be true in some cases. Some tires construction/compounds react differently to different pressures. On the E90, we were running 295/30R18, and still targeting high 30's for pressure. Only way to really know is to test.
When you say car felt like it was on ice skates, was it the whole car or just one end (front or rear)? Also, were you at 35 all around or 30 front / 35 rear?
off-road tires is a whole other game - sort of like comparing baseball to badminton.
*mini thread hijack - is that Blackhawk Farms?)Last edited by NigelStu; 04-03-2012, 11:36 AM.Ben
We are a Des Moines based team. Our first race is Brainerd in June. Then IA Speedway in August and Road America in Oct. Anyone planning on being at those races? We are a new team with an '89 325i. We have about a dozen Chump/Lemons races between myself and the other car co-owner with other teams. We also have two new drivers to Chump, but with prior autox and track day experience. Would be great to connect with other E30 Chump teams.
So starting at say 30 psi cold all around should be a good starting point for testing purposes?
Originally posted by akorcovelos View PostIm running 225/50/16 so im guessing larger dia tires require less pressure. Makes sense since huge offload tires require way lower pressures.
I agree that starting at 30psi cold would be a good place to start. We usually start the day at 29psi or so. It also depends on ambient temperature, track temperature, how hard you guys run and how hard the track is on tires.sigpic
