Whats the Most Durable Guibo for Track Use?
  • Lof8
    • Oct 2006
    • 2827
    I was getting a horrible whine on the way home from my last track day. I kept thinking to myself I'm going to have to look into a rebuilt trans. I'm pretty glad to have found this toasted guibo that looks like it was allowing some metal to metal rubbing.
    This thing is barely a year and a half old. What are you guys using with more success? I don't think I want to use anything completely solid, but theres got to be a more durable option than oem.
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • KenC
    King of Kegstands
    • 14396
    Your driveshaft u-joints are likely worn out.
    If it wore out that quickly, it's from a wobbling driveshaft. A new CSB will "fix" it for like a month. You need a new driveshaft.
    Originally posted by Gruelius
    • ak-
      • 12422
      Dunno.
      My knowledge was that unless you have solid/poly all the way around the car it is okay to use poly for the guibo since it needs some sort of flex.
      Don't Corvette's or something share the same guibo as us?
      1991 325iS turbo
      • Lof8
        • Oct 2006
        • 2827
        My driveshaft was rebuilt a couple of years back. I sure hope they're not worn out.
        The revshift guibo looks pretty sturdy, anyone have experience with that one?
        S50'd
        • KenC
          King of Kegstands
          • 14396
          There's no reason for an 18mo old giubo to wear out that fast. Either your output prop of the tranny is wobbling or your driveshaft is.
          • Lof8
            • Oct 2006
            • 2827
            I will certainly check the rest of the driveline for slop and wear.
            S50'd
              I agree, with a stock engine premature failure of a guibo will be from a bad drive shaft or a bad transmission.
              • blunttech
                • 12850
                or improper driveshaft alignment. Is this a swap car? And if so what motor and what mounts are you using. Deflection kills guibos. As stated.. A good quality OE Febi/Bilstein guibo is all you need
                sales@blunttech.com
                www.blunttech.com
                Like us on Facebook
                • Lof8
                  • Oct 2006
                  • 2827
                  This is an S50 powered track car. I do HPDE's and autocrosses, so all of its miles are pretty tough. The swap was performed 3 years ago and that may actually be the age of the guibo. Next time I'm under the car, I will check for u-joint slop, csb slop, and do my best to test for output shaft slop.
                  I'm using a g260 with modified trans bracket and green mounts. I do have to shim one of the mounts with a couple of washers for it to carry some load, otherwise there is a gap.
                  I hope that the rebuilt driveshaft is not already sloppy or maybe out of balance?
                  S50'd
                  • KenC
                    King of Kegstands
                    • 14396
                    Ditto this. Didn't know it was a swap.
                    • Lof8
                      • Oct 2006
                      • 2827
                      Since I'm getting some solid feedback here, let me throw in some more variables. My trans doesn't leak at all while sitting, but after a day at the track, I have some trans fluid sprayed on the rear of the car that seems to be coming from the trans input shaft.
                      I recently replaced the trans mounts with urethane and the vibration was horrible. I went back to oem mounts and it went away (95%). It seems I do have a driveline vibration that is hidden with rubber mounts. I was hoping this worn guibo would be my culprit.
                      I'm trying to exhaust all avenues before swapping out the trans.
                      Thanks for all the ideas.
                      S50'd
                      • iamsam
                        • Jun 2008
                        • 173
                        Didn't read the whole thread, but this looks more durable. https://www.revshift.com/shop/24v-sw...-flex-disc.php
                        • 87e30
                          • Jul 2008
                          • 5676
                          PS wobbly driveshafts may exist, but to really see if it's going bad you need to see if the unjoints are binding (too tight and causing the shaft to put excess pressure on the CSB and guibo)
                          I knew mine was bad when it was out of the car and I could move it one direction smoothly but the other it caught.
                          If this is redundant information just ignore me.
                          I just hate everyone.
                          No need for discretion.
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            just want to say
                            I run an s50..and almost solid akg motor mounts and uuc red trans mounts...
                            I have almost no vibrations to speak of......
                            so perhaps something is off in your set up/drivetrain
                            • Jean
                              • 18228
                              Exactly what I was going to say as well as I read the first posts. Alignment issue can and will eat your guibo. My guibo in the m30 car is like new, after going through hell all of last season on race tires.
                              I went through 3 m10 guibos before the swap and it was caused by the bad driveshaft and alignment.
